They're designed for the Meguiars buckets but fitted on my generic 5 gallon bucket fine - https://www.slimsdetailing.co.uk/products/martin-cox-5-gallons-litre-bucket-with-free-bucket-barrier
Thanks, I have those buckets too from ECP.
I used to watch Obsessed Garage on YouTube years ago, and recently took a look at what he's up to now. Looks like Matt's business is doing pretty well so I went to his website to see what he sells.
I can't believe that people pay $787 for a few cleaning products![]()
What is the APC of choice nowadays? I need something to help clean the door shuts/jambs.
Whilst on the topic of APC's - I do use Bilt Hamber Surfex HD diluted for the exterior however any recommendation's for a more interior driven APC?
It's just that the smell does not make me think oh I will pair it with interior plastics and upholstery.
I use this for my interior. Works really well and leaves a lovely finish.Whilst on the topic of APC's - I do use Bilt Hamber Surfex HD diluted for the exterior however any recommendation's for a more interior driven APC?
I've always used https://www.gtechniq.co.uk/shop/auto/wash-decon/w5-citrus-all-purpose-cleaner/
I'm sure there are better smelling ones out there, but the citrus smell isn't offensive, at least to me![]()
https://www.car-chem.com/shop/interior-clean-coat
Autofinesse Verso smells quite nice, used it on my carpet mats with a wet vac and used it on the plastics before using a dressing.
It does have a fragrance, it's not like having an air freshener in the car but it is a clean pleasant smell.I usually use Citrus in the way I use Surfex HD as an exterior pre wash.
No doubts that Citrus is capable of deep cleaning interior surfaces and fabrics however I’m looking for something which after generous use on fabrics/upholstery leaves a lingering freshness to the interior.
Might well replace my Surfex HD with your suggestion once’s it’s runs out as could not decide which brand to go for as most offer a Citrus product these days.
I go through phases with interior dressings and usually use diluted Car Pro Pearl.
Appealing that Clean Coat is a 2 in 1 - Does it have a pleasant fragrance as have used a similar product before which did.
I was looking at both Total and Verso and it seems Verso is more versatile than Total with all the same benefits.
Been wanting a Wet Vac for a while and your car mats post has me seriously considering one and did wonder if you could use other products with them as I imagine being tied into Bissel products wouldn’t be cheap over time, what dilution did you use for the wet vac?
Thanks all![]()
I wasn't a fan of car Pro perl, still got about 800ml of the stuff.
Thanks all![]()
Bilt Hamber Surfex HD, works even when heavily diluted and can be used for everything - on wheels, as a pre wash etc
I picked up 5L of Auto Finesse - Verso this morning from ECP.
When time permits going to go all out on the interior!
You could have had nearly 5L for free that I got a few years ago when Auto Finesse was the latest hype brand, I never thought they were anything special.
It's only taking up space in my garage.
What do you prefer to use instead?
