- 8 Dec 2002
- North Yorkshire
Slight hijack, but what monitor arms are you using? All the ones I have looked have the arms drop on dual 27inch monitors which is what happened with the ones I used at work.Fancy stuff. But I do recommend the vesa mount for the displays with a couple of proper monitor arms. Will give you much more flexibility.
