The AMD Driver Thread
I got directed to that link by the driver, I've tried a few of the steps. Namely removing all the old C++ redists (a few had Chinese/Japanese descriptions/uninstall menus... which was weird?!) and ran the various DISM and SFC commands. Dism found and fixed something, although I didn't fancy trawling through the logs to see what. After a reboot the driver was installed ok, despite the error.
Initially fired up HZD to be greeted with with an even more annoying glitch than previously. Rather than shaking trees/ropes, I had constant hud flickering and black frames. Jumped to another game for a bit with no issues, then back to HZD and it was ok again.
Fingers crossed it's sorted itself out!
Hopefully that’s sorted it.
Does anybody know a fix for the driver timeout error?
Playing Tiny Tina's Wonderlands I get this error all the time. Last night was 4 times in about 30 minutes. I ended up rage quitting in the end.
I have tried the latest drivers and rolled back to previous but still no good.
Running a 5700XT with an undervolt but also tried default settings also
Is your card overclocked?
This might be worth taking a look at:
https://www.amd.com/en/support/kb/faq/gpu-800
Also mentions Corrupted Windows® registry or system files in that link, so perhaps a quick run of SFC /scannow (elevated as admin) might be in order (as well as DISM /Online /Cleanup-Image /RestoreHealth). That'll help rule out local system corruption.
I used to get this a lot, Started installing the driver only option for the drivers and using MSI afterburner to manage clocks and a fan curve that keeps GPU Mem temp under 80. Additionally, limiting frame rate to 60fps seems to help too - it definitely feels less stable the higher the FPS.
I'm currently running the card at 2050/1850@1120mv on the 22.4.1 drivers and its fairly stable.
Still get the odd crash here or there, but I suspect it's more related to rubbish RAM tbh.
Are you using a TV for a monitor by any chance?
If so reducing the colour profile to YCbCR 4:4:4 stops the timeouts.
Personally I had to revert to driver 21.10.2 to fix the timeouts on my LG C1.
AMD Software: Adrenalin Edition 22.4.2 Highlights
Support For
  • Vampire: The Masquerade - Bloodhunt™.
Fixed Issues
  • Display mode of 4K 120Hz may be missing on some FreeSync™ displays using some AMD Graphics Products such as Radeon™ RX 5700 XT.
Known Issues
  • GPU utilization may be stuck at 100% in Radeon performance metrics after closing games on some AMD Graphics Products such as Radeon™ 570.
  • Some users on Windows® 10 operating system may observe the absence of the windows transparency aero effect.
  • Display may flicker black while switching tabs between video playback and gameplay on some AMD Graphics Products such as the Radeon™ RX 6700 XT.
  • Using Radeon™ Super Resolution on 2560x1600 resolution displays may produce a system hang. A temporary workaround is to set the display Scaling Mode to Full Panel.
  • Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
  • Radeon performance metrics and logging features may intermittently report extremely high and incorrect memory clock values.
Package Contents
The AMD Software: Adrenalin Edition 22.4.2 installation package contains the following:
  • AMD Software: Adrenalin Edition 22.4.2 Driver Version 21.50.21.07 for Windows® 10 and Windows® 11 (Windows Driver Store Version 30.0.15021.7000).
Important Notes
  • Ryzen CPU Overclock settings may be changed after resetting or importing a profile from Radeon Performance Tuning Options. Users will now be notified of the applicable devices being changed.
  • AMD Software Capture and Stream features and Overlay support for Clone mode and Eyefinity display configurations will be introduced at a later date.
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-22-4-2
AMD Software: Adrenalin Edition 22.5.1 Highlights​
Support For​
  • AMD Radeon™ RX 6650 XT Graphics
  • AMD Radeon™ RX 6750 XT Graphics
  • AMD Radeon™ RX 6950 XT Graphics
Fixed Issues​
Known Issues​
  • Performance drop may be experienced while playing Fortnite with Multithreaded Rendering and DirectX® 11 API on some AMD Graphics Products such as the Radeon® RX 6900 XT Graphics.
  • Display may flicker black during video playback plus gameplay on some AMD Graphics Products such as the Radeon™ RX 6700 XT.
Package Contents​
The AMD Software: Adrenalin Edition 22.5.1 installation package contains the following:
  • AMD Software: Adrenalin Edition 22.5.1 Driver Version 21.50.21.11 for Windows® 10 and Windows® 11 (Windows Driver Store Version 30.0.15021.11005).
Important Notes​
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-22-5-1
AMD Software Preview Driver May 2022 Release Notes​
Highlights​
  • Radeon™ Super Resolution
    • New “Sharpen Effect” slider that allows you to fine-tune the sharpness effect of RSR to your own desired settings.
  • DirectX® 11 optimizations for Radeon™ RX 6000 series
    • Up to 8% increase in performance in DirectX® 11-based games, using AMD Software Preview Driver May 2022 on the Radeon RX 6950 XT, versus the previous software driver version 22.5.1 RS-470
  • AMD Smart Access Memory optimizations for Death Stranding™ and Watch Dogs™: Legion
    • Up to 10% increase in performance with new SAM optimizations in Death Stranding™ @ 1440p Very High settings and up to 13% increase in performance with new SAM optimizations in Watch Dogs™: Legion, using AMD Software Preview Driver May 2022 on the Radeon RX 6950 XT, versus AMD Software: Adrenalin Edition 22.5.1RS-471
    • Up to 12% increase in performance with new SAM optimizations in Death Stranding™ @ 1440p Very High settings and up to 24% increase in performance with new SAM optimizations in Watch Dogs™: Legion, using AMD Software Preview Driver May 2022 on the Radeon RX 6950 XT, versus AMD Software: Adrenalin Edition 22.5.1RS-472
    • Up to 6% increase in performance with new SAM optimizations in Death Stranding™ @ 1440p Very High settings and up to 6% increase in performance with new SAM optimizations in Watch Dogs™: Legion, using AMD Software Preview Driver May 2022 on the Radeon RX 6950 XT, versus AMD Software: Adrenalin Edition 22.5.1RS-473
Known Issues​
  • Visual corruption may be seen in-game menus on Age of Empires™ II: Definitive Edition and Age of Empires™ III: Definitive Edition using Radeon™ RX 6000 Series.
  • Some textures may flicker during movement in War Thunder™ using Radeon™ RX 6000 Series.
  • Foliage corruption may be seen in The Elder Scrolls® Online with ultra pre-set settings using Radeon™ RX 6000 Series.
  • Performance drop may be experienced while playing Fortnite™ with Multithreaded Rendering and DirectX® 11 API on some AMD Graphics Products such as the Radeon® RX 6900 XT Graphics.
Package Contents​
The AMD Software Preview Driver May 2022 installation package contains the following:
  • AMD Software Preview Driver May 2022 Driver Version 22.10.01.03 for Windows® 10 and Windows® 11 (Windows Driver Store Version 30.0.21001.3006).
Important Notes​
Two new sets of drivers out today! :eek:
Standard release with support for the new 6X50 cards and another with a couple of new features.
RSR sharpness slider, DX11 optimisations for 6000 series cards and SAM improvements for a couple of games.
I see people are reporting huge increase in performance in DX11 games, that's nice even if it is very late for this generation.
41% for 1% lows? That is insane
With the latest AMD beta drivers, is the RTX 3080 still ahead of the RX 6800XT (on average) in DX11 games?
Is it a small difference, or actually noticeable?
EDIT - Now that I think about it, the ray tracing performance is still going to be worse...
I tried the preview driver on my VR sim rig and got a strobe (flicker?) effect in my Reverb G1. -Submitted a bug report and hope they can fix it quickly. The older driver wrks fine, but I would like some of that free performance boost in VR.
