AMD Ryzen 7 5800X3D retail processor has been tested ahead of launch
18 Apr 2010
Dorset
Why's that? Bios is generally pretty straight forward to update. Or is your board awkward?
I just remember I tried doing it a few years ago and I had quite a few problems as I tried updating the bios by the internet rather than through a usb drive and was just probably just unlucky. I just looked at a quick YouTube guide to refresh my memory and it’s seems straightforward enough so probably overthinking it.
4 Oct 2017
Definitely don't do any online downloads, or use software to update the bios through Windows.
Old school way of downloading to USB is best in my opinion.
28 Sep 2018
That's so badass! The number you want to pay attention to is the "CPU Game Average." That's what should be compared not the overall average when using SOTTR as a CPU bench test.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Theres quite an easy way to prove it - thats by actually watching the review - since they list every single part used in both systems.
TL:DR
NO, they use the fastest DDR5 - 6400 the system supports, and is £500 worth.
Robert Hallock talked about how due to their technology advances they have many leavers they can pull to keep competitive.
Yeah well they pulled a leaver.... :D
1 Nov 2019
Europe
In the short, big/little is crap, in theory it should have way better efficiency, but in the practice big/little doesn't work that way, it only supplements MT workloads. It would be better to have fewer big cores than combination of big/little because big cores if tuned correctly are very efficient in light workload, and also less latency which benefits games, not to mention how easier is to optimise software for all same cores design. I say from the beginning that big/little should be erased from the desktop PC. 3D stacking cores isn't far away, and as soon they start using it, no one would need to create small cores.
Caporegime
8 Jan 2004
Rutland
Intels BIG.little is junk. Its just a sticking plaster for their power issues.
1 Nov 2019
Europe
Fact, it only complicated things, they use big/little not because it is superior, but because they don't have ready chiplet design which will allow them to pack much more big cores, and chiplet design with 3d stacking cores that i mention before is the future and will allow them to put as many cores as they wan't, so Intel will forget those big/little horror.
6 Aug 2009
Bingo, and their power issues are a result of lacking in other departments, increasing frequency and power draw to compensate. They are still a good few generations away from competing in all areas with AMD.
30 Aug 2014
Some rumours suggest (pinch of salt) AMD will be doing their own version of Big.Little with Zen 5 although different to Intel's approach and the little cores will still be strong.
1 Nov 2019
Europe
They don't need big/little design that Intel use, that's the whole advantage of using chiplets, putting more cores while retaining good yield.
