I wish I had bought one of these rather than procrastinating about selling the 5950x.
DO you think scalpers are buying these too?
Really need to check forums and ebay to see if idiots are re-selling them....
Fomo is the devil.
I have just ordered to replace 3700x.
Fomo is the devil.
Fomo is the devil.
What sort of real world gains are people seeing on at these IE not the 1080p with a 3090 etc.?
I bought one only because I saw stock level going down insanely fast, but I'm not sure if I should proceed installing it...I wish I had bought one of these rather than procrastinating about selling the 5950x.
It's a toy that is nice to have, not something vital for life.Do you need it? Can you afford it? Is it replacing an existing CPU you can sell to offset the cost?
Quick test of Shadow of The Tomb Raider, 1080P lowest settings.
5950X 3800Mhz CL14
5800X3D 4000Mhz CL16
Measuring the CPU results from the above.
Min FPS: 5800X3D 19% faster
Avg FPS: 5800X3D 17% faster
Need to properly tune the 5800X3D memory next, apply some thermal paste between the cooler and the CPU (I wanted to quickly get some results out) and then reinstall the OS.
6800 XT Midnight Black Edition.
Maybe. Try gear down mode on for over 3800. I got mine stable by putting VDDP and IOD up to 1.1v and SOC up to 1.125v.Nice one dude, tried to get to 2000 since my stick is 4000c16 but only got as far to 3800 for the 1:1 which isn't bad. 3866 booted but my god it was possessed af, everything so flaky and event viewer was screaming like Hell with WHEA errors. Maybe if I up the voltages it would be a better result
This is the best I've managed so far in Aida64 and RAM Test, it looks to be stable.Gear down mode is normally enabled for my stick as It's a dual rank 16gb module for 32 in total. Will give it a shot
I was considering one of these but I play at 4k and it seems there is no performance gain over my existing 3600x, so I'll give it a miss
£410 is a crazy expensive price too
Noice, it seems the IF on this processor isn't great but 3800 1:1 is still a decent upgrade from my 3900x's 3600. Just need to tune my ram more instead. Maybe a bios update for my hero board (not dark) would help.
