@CAT-THE-FIFTH A new review has just popped up for the 5800X3D from Igors lab. AMD Ryzen 7 5800X3D - the only (and last) fighter of its kind as a perfect and very efficient upgrade | igor'sLAB (igorslab.de)
It shows the 5800X3D is the fastest CPU tested, while using the least power of every CPU tested.
How did Steve Walton get to +1% 1080P > 5800X3D, i was looking at it and thinking that can't be right, the 5800X3D seemed to be getting consistently bigger wins vs the 12900K, IE more than 1%, consistently.
So i did some maths.
The average frame rates at 1080P
5800X3D:
668 + 322 + 172 + 255 + 55 + 204 + 266 + 161 + 577 + 314 + 411 + 185 + 145 + 265 + 240 = 4240
12900K:
582 + 291 + 201 + 206 + 58 + 214 + 255 + 150 + 558 + 304 + 398 + 189 + 144 + 232 + 212 = 3994
4240 / 3994 = 1.061 That's 6%, not 1%.
https://www.techspot.com/review/2450-ryzen-5800x3D-vs-core-i9-12900k/
You add up the same numbers, you get the same result no matter which order you add them up in, they are the same numbers, 1+4 = 5, 4+1 still = 5, with that if you divide A 4240 by B 3994 you get 1.061, if you turn that around and divide B 3994 by A 4240 you get 0.941
So the first way is A (5800X3D) vs B (12900K)
The second way is B (12900K) vs A (5800X3D)
your method is scientifically flawed is what we are getting at. It doesn't really matter as HUB methods are flawed as well. Only fan boys care about it in the long run.
ordered one of these to go in to SSF system with a SF750w psu. Should help with keeping total wattage in check with the increases expected with the next set of GPUs coming out
Incredible on the power efficiency side - imagine a 'clocks per watt' between the two.
Its the way Intel pushed the power levels to frankly stupid levels just to get another 2% out of the 12900K, its 80% higher, Its looking like Nvidia are going to be doing the same, at what point is this sort of behaviour going to far, once these components heat up the planet by how much infrared radiation the pump out?
Everyone will have their own mini power station in a couple more generations![]()
Igor's Lab said:"The gaming performance, no matter what the test field of games looks like, is only one side of the coin, because you also have to invest a decent amount of electrical energy to achieve such a result.
But when you consider that the Ryzen 7 5800X3D in Full-HD still offers 2.8% more performance with only 39.4% of the electrical power (of the 12900KS), then you don’t even have to discuss the gaming crown.
I actually see the Ryzen 7 5800X3D more as a feasibility study that can impressively show how the deficits of current processors can be extremely reduced, at least in some areas. With the help of the 3D V-Cache, the Ryzen 7 5800X3D looks more like a new CPU generation than a pull-up to prove anything to anyone else, no matter what the cost."
"Fanboy" right, now i get why you still haven't dropped this, now i get the dogged deterministic mental gymnastics to gaslight the method, what i got wrong was using the individual published slides instead of the full chart, that's a mistake i had already conceded and here you are still trying to gaslight me. Whose the fanboy?
I gave you the result using your method on post #198, to which you never responded, would you like to do that now?
