Have downloaded this, will try and get it to build when its finished verifying.
Great let me know please,i have a feeling my 32GB of RAM is the problem, it may need 64GB.
Also 20GB+ for URE5. My H: drive is a SATA SSD so will take a long time.It finished verifying, then moved the data(92GB) from C:\temp to H:\Documents and its verifying it again, its 101.3GB nowAlso 20GB+ for URE5. My H: drive is a SATA SSD so will take a long time.
Edit
Its open, recommended spec:
12 core CPU @3.4Ghz
64GB RAM
RTX 2080 or AMD 6000+
Min 8GB VRAM
Thanks, its packaging in now.Go to;
Edit > Editor Preferences, in the search field type "Long" check the box that says "Enable support for long paths (<260 Characters)" then > tool bar at the top select platforms > windows > check shipping > click on package project, It will ask you where to save it, once selected it will start to compile the game.
All I see in the preview is a black screen with the white text showing the req spec.
It crashed! think it’s because it ran out of hard drive space. It had 50GB free before it started, just looked and its now zero free. Moving 80GB to a different drive and will try again.
I am moving the project to a NVMe drive with 700GB free, its eaten ~300GB so far with all the cache and vault!
no other engine that i know of does this.Its working on it again, using 40.4GB RAM and increasing.##### ridiculousno other engine that i know of does this.
Have 64GB in this PC and it looks like it will use it all, @48GB now![]()
It says its done, what now?You might alight then, fingers crossed...
Edit
ran exe and it worked for a few seconds then crashed![]()
That would be great if you don't mind.
