Caporegime
- 8 Jan 2004
- Rutland
Will give that a try, thanks.Don't use just cleartype, use Better Cleartype Tuner. 2200 @ RGB.
Yeah having used the monitor for a number of weeks now the VRR flicker is probably my only real annoyance.UPS Delivered on the day after shipping, no significant damage to the box, tamper tape intact. I have been using this monitor since Friday, I absolutely adore it! HDR films through MPC-HC are incredible, gaming is wonderful, and the text fringing looks like very fine/tiny chromatic aberration from a normal distance. Not ideal, but to me its a minor issue. My biggest issue is the VRR flicker. It's pretty noticeable, even at ~120fps when running 144Hz GSync. Black stabiliser helps a little bit but doesn't fix it. If you are busy in game or its a brighter scene, it isn't a problem.
Just ran Better ClearType Tuner with 1600 RGB and it seems pretty good (at 2200 text looks too a little too soft and grey imo). I will do some more testing with documents this week. I can control the lighting in my room, but even with the blinds open, black levels stay dark. Day to day I am running Creator mode, sRGB, 52 brightness (approx 120nits). A friend has a calibration kit which we will use to verify how the out of the box colour accuracy performs at 120nit, as the calibration report says its done at 250nit (100% brightness in SDR). But, photos and videos just pop even in SDR, colours are very natural.
Yes, Would've been nice to have bfi on the AW with the higher brightness and hz (i game in the dark at low brightness).
Was looking at the 42c2 until I saw they dropped the bfi @ 120. Went for this screen, but still a while to wait.
I'm still hurting from the transition between crt and LCDStill chasing res scaling, motion clarity and although oled tech has hit and passed the crt black level (crt had a faint glow), it still doesn't look as natural as high end crt. Obviously everything else is better on the new tech
Tbh I play with a dim screen, so with bfi I turn up the brightness and I'm happy. The brighter AW would make bfi a little more acceptable for those that like it a little brighter than me.What's the point of wanting BFI anyway and then saying you want a screen that's even brighter than the AW, BFI just makes any screen look dim it's not compatible with wanting a bright image
I thought this might be the case, but I think they still want to try it out of curiosity. I don't think I'll be applying any calibration profiles from its output like I did for my previous displays though.@Alienwhere you can’t just hook up a colorimeter that’s not profiled to a spectro with enough resolution to properly read the spd of QD oled’s. Something 5nm or below.
1) At least on mine the fan noise is honestly kinda random. Sometimes I can have been using the screen for a while and it'll be inaudible and other times it's quite noticeable. If I had to pick a time where I feel like I've heard it most it would be when the ambient temperature in the room is quite hot combined with me having had the monitor on for a number of hours consecutively.I can't hear a fan at all on mine. Under what circumstances is fan noise most audible?
I've asked Dell for the promised refund, anyone else had there's?
It's normal for brightness to change slightly with the amount of white on the screen?
2) Got my delay compensation refund within a week of requesting it after it was delivered.
3) Sadly normal for OLED due to ABL. On SDR I don't get it with the brightness set to 50. It's noticable in HDR with the HDR1000 mode though. I've got a OLED TV already though, so I've kinda gotten used to it.
Bit of a weird thing with the downlight.
If it's set to a lighting effect, like rainbow cycle, the downlights are turned on with the others. If I set every zone to a static colour, including the downlights, then the downlights aren't lit.
