Is the IHS not soldered on these?
Yes they are, I assume the Liquid metal is on top of the IHS.
I have finally installed my 5800X3D now MSI have released a BIOS for my B350M Mortar. Using a Cooler Master ML240L and I see temps in the mid 80's when running CB R23 at stock settings but a quick PBO2 tuner tweak to -20 all core got that down to low 80's with higher clocks at a 15k score.
Not had much chance to try it in games but I did load up Path of Exile and in the 1st town the graph shows 2ms frame time for CPU load which is down from around 10ish on the 2200G so not a bad improvement. I cleared a few mobs and didn't notice any drops but I need to play further in to get a better idea really as mob density is pretty low at the start. In game temps with the -20 offset are mid 60's with a quiet fan profile.
Check the reviews. Not everything benefits from the extra cache, gaming is one that does see a good boost but it varies on the game and some even lose a little performance due to the reduced clocks. Most other workloads don't see any improvement.Worth swapping my 5800X for this? £200-250 seems to be the sale price, maybe a bit more on eBay.
Clocks look slightly lower base & boost but get the 100MB L3 cache, anything else better?
Not worth it IMO unless your running 1080p with an 80 class GPU and even then your only looking at around 10-15%.Worth swapping my 5800X for this? £200-250 seems to be the sale price, maybe a bit more on eBay.
How did you get/do the Higher clocks ?
PBO2 Tuner. Need to set up a powershell script or batch file to call it from the command line on boot / login at the moment because it resets after a reboot but other than that it worked fine for me.
I tried -20 across the board and that worked fine without issues and allowed all core in R23 to go from around 4.25Ghz to 4.45Ghz. It also dropped temps by a couple of degrees but it is still low 80's in CB even with a 240mm AIO. Not using any offset mounts or stuff like that.
How do you find running 2T Vs 1T?Got 5800X3D purring like a little kitten. Memory dialled in and stable as a rock.
I have not yet been able to get 1T stable unless Geardown mode is on, and generally T2 is better than Geardown enabled.How do you find running 2T Vs 1T?
Just got the email that mine has been shipped, so I guess they're back in stock now?
No stable BIOS with support for it yet on my Tomahawk though, there is the beta BIOS based on 1.2.0.6c but 1.2.0.7 is the one with the fTPM fix.
Mine is running on a Tomahawk what is wrong with fTPM![]()
Seems more like a DPD fault. Phone their customer service line and speak to an agent. Maybe you can get the driver to try and deliver before EOD.Well this is a bit frustrating... I paid extra to reschedule for today, but DPD messaged they "missed me". No one approached the door and even checking Ring footage there was no DPD van at all. To DPD support I go... or will contacting OcUK be better?
On the other hand, noticed MSI marked the beta 1.2.0.6c BIOS as stable for the Tomahawk, so guess I'll download that for now.
Yup just did that. Apparently my local depot marked a bunch of deliveries as missed for some reason. They're trying to see if they can get the driver to attempt it today. Was hoping to spend this weekend tweaking the CPUSeems more like a DPD fault. Phone their customer service line and speak to an agent. Maybe you can get the driver to try and deliver before EOD.
Poor from DPD, particularly given you paid extra. Usually they are quite good.Yup just did that. Apparently my local depot marked a bunch of deliveries as missed for some reason. They're trying to see if they can get the driver to attempt it today. Was hoping to spend this weekend tweaking the CPU![]()
