Half a paragraph further down it literally says as much..Then why did you post a review that wasnt even testing for your theory and then pretended it supported your theory??? Go ahead then, post a review where when both tested at the same frequency, the e core is more efficient. There isnt any cause that is not the case
That means running Gracemont above 3.2 GHz is pointless if energy efficiency is your primary concern. Running the E-Cores at 3.8 GHz basically makes them worse P-Cores. But that’s exactly what Alder Lake does by default.
Below 3 GHz, Gracemont shines. It’s able to maintain better performance at very low power targets (as we saw in the previous section) while consuming less energy. With an integer workload, it’s especially efficient.
Because to get better efficiency than E cores that's where they need to be clocked?And that is relevant...? Why would they run them at 3.5 ghz?
Unless you work for AMD it is just as good a guess as anyone else.
