I’ve ruled out the 330e and am deciding between a 330i and m340i now. I’ve found similar cars around a similar price. The standard spec on both cars is very good and The only things I want to make sure the car has is the Harmon Kardon speakers and I quite like the heads up display. I’d want apple car play and wireless charging too but the salesman said not all cars have apple car play and it’s awaiting a software update if it doesn’t have it?
Is there anything else crucial for the spec that I’ve missed? This would be my first bmw so I’m not too familiar with all the options and packs.
I take it you’re looking at the new shape, as you mentioned M340i
Options wise, HK is a good one if you like your music, as is the HUD.
Otherwise, you’d be looking at things like adaptive lights, heated seats (if they’re not standard), acoustic glass (I think part of the rear tinted window pack).
In terms of engine, well it entirely boils down to whether you want a 6 cylinder or a 4 cylinder.
The 330i will be quick and it’ll feel sporty enough. If you enjoy hooning your cars down the A4069 and the like, the M340i with it’s more powerful engine and LSD will feel even sportier.
The M lite is closer to the M3 than the previous gen is.
You then need to consider the current climate. If you’re stretching your budget for an M340i, it may not be wise to get one - if cost of living keeps spiralling out of control, will you regret your purchase and have to sell it anyway?
If not, and you have the spare money, I’d be tempted to buy one of the best non-M cars BMW has made, and certainly one of the last
