Yes will be interesting to see what they do. AM5 with DDR5 and then AM4 cheaper with DDR4 but still decent CPUs could cover most buyers.Apparently the 5800x3d is not the last cpu for am4 platform. So gonna hold out and see what else comes
I found this the most useful guide by far;
How-to-undervolt-AMD-RYZEN-5800X3D-Guide-with-PBO2-Tuner/README.md at main · PrimeO7/How-to-undervolt-AMD-RYZEN-5800X3D-Guide-with-PBO2-Tuner
Get the Most out of your 5800X3D using PBO Curve Optimizer! - PrimeO7/How-to-undervolt-AMD-RYZEN-5800X3D-Guide-with-PBO2-Tunergithub.com
Thanks for posting that Bottle! Five minutes to set up and a nice reduction in temps plus better all-core frequencies (I'm running my 5800X3D in an NZXT S340 case with an Arctic Freezer 34 eSports cooler and the temps weren't great before - maxes out in the low 80's now).I found this the most useful guide by far;
Borderlands 3 shows a really nice uplift over my 5800X -
Can't wait to see 3dcache second generation on Zen 4 with increased clock or even better, OC enabled.Imagine this thing with the same clock speeds of a 5800X, 4.85Ghz (+8%) that ^^^ would be +30%, or 208 FPS in that scene.
To be hitting 5.5 GHz all core heat is obs well controlled so the 3d version might be quite something
I think I may have an issue somewhere in my system, Even with the 3D I'm still only getting low GPU usage at 1080P in a fair few games on a 6950XT, Confooozing![]()
"Still" ? this suggests you have something to compare it to? a previous CPU?
Yep comparing it to my 5800X non 3D, Averages and minimums have gone up but comparing my results against reviewers with a similar system I seem to fall short in all game benchmark numbers, In some by quite a hefty margin.
SotTR, how does it compare to this?
I can't put it on Ultra, my GPU isn't anything like fast enough to make the CPU a bottleneck but.....
I'm downloading it again now if you want to run some comparisons.
Appreciated thanks, You'll have to give me until tomorrow though, I'm on a 2MB line so will take me a while to download it![]()
