Dashcams!
Permabanned
24 Jul 2016
South West
Just checked the box and although it mentions a sucker mount on it there's nothing in there. Had it fitted by Halfords so looks like it's gone walkies.
No idea fella mine came with both. Should look like this.
20 Oct 2002
North West
So just been hit by a lorry on the motorway, he didn’t see me and needless to say any closer and I would’ve been squished. Managed to slam on (inside lane, next to a temporary barrier) powerfold mirror clean off…lots of paint damage. Guy was fine…so hopefully shouldn’t hit issues with claim.
Now really want a Dashcam…what to go for? Want great functionality/app/hardware not sure about rear cam? Would like it fitted tbh
7 Apr 2008
Lorville - Hurston
******* hell. Are you OK?
Underboss
20 Oct 2002
Oxfordshire / Bucks
@Scania fault :p :D
seriously though, hope your ok
currently on offer :
Caporegime
17 Jul 2010
I have a road angel Halo Drive that I'm very happy with. 1440p (the minimum you should buy imo to enable you to make out reg plates) and very easy setup. They have an app you can connect to the camera too and download clips directly to your phone.
20 Oct 2002
North West
The dashcam has been installed. Only took about 20 minutes and they’ve done a great job, I can’t even see where they’ve put the cable other than the bit going down to the cam. The rear cam works surprisingly well too - it’s a decent solution for a soft top. I’ve connected it up to the app, updated the firmware and have set up parking mode.
Who fitted?
Halfords fitting any good? Reckon £200 is my limit
1 Apr 2014
Aberdeen
I'm glad you're okay.
Definitely get a rear camera, so you can have a record of the scrote running into you and possibly show why they crashed into you (e.g. on their phone). Strongly consider an internal camera too (i.e. a triple camera dashcam) to counter claims that you were using / fiddling with your mobile phone or otherwise not paying attention.
Caporegime
25 Nov 2004
On the road....
@Scania fault :p :D
Not guilty m’lord! :D
But seriously, blind spots in trucks are unbelievable, I’ve recently had a near side camera monitor fitted to my artic, I’m aware of blind spots, but, it’s been a shock - not least a revelation - to me just how many cars & vans are invisible to my mirrors yet picked up by this new camera….
Basically, stay away from trucks, we can’t see you!
V_R
V_R
17 Jan 2007
UK
Blimey, glad you're ok, deffo get a dashcam.
I fitted my hardwired Viofo A129 Pro Duo myself, very easy and a decent camera setup too, front and rear, parking mode, G Sensor. Recommended.
