- 19 Jun 2022
- USA
oh, ok. sounds great. I kinda wanted the rose gold. but thats ok.They went Thunderbolt 3/USB-C only 2016 onwards!
what does this mean?Yeah I guessed right. You need to plug in the USB PD Charging port into the wall (using an appropriately rated PD charger, not your 30w Apple charger), then the other ports will output power as expected. USB-C PD spec is a confusing mess.
A USB hub wasn't powered properly, so it wasn't delivering power at the expected rate.what does this mean?
Spilled an entire pint of juice into my MacBook Airsilly me. Living with parents without accidental damage cover (not that I’d ask) and no idea when we’ll be moving to our own house so… £780 for replacing basically everything bar the case. The water even got into the screen
Well when I say juice I mean squash so it was mostly just flavoured water with no sugar.I can only imagine what a pint of juice would do to my insides, let alone your Mac
It is very annoying, however it's not the only way.I just reluctantly went and bought a Air M1 - I bought it for one single reason and that's onboarding iphones into MDM which can only be done using a MAC. Havent opened it just yet but Apple, really? forced to have a Mac to onboard an iphone, total shambles, even worse if you want to onboard their laptops you have to have an apple phone. Phones to onboard laptops, laptops to onboard phones... Smart way to force you into the ecosystem.
Edit: Perhaps its because im a windows user but im instantly finding stuff about it that I dont like![]()
You can get your VAR or vendor details entered into Apple Business Manager and they can add the device into their for you, from Apple Business Manager you can then import into Intune, airwatch etc.
If you are doing just the odd phone bought from Apple, you'll need a mac...
Just a case of you aren't used to it. I'm a macOS user and have to use Windows 10 almost daily and it infuriates me.Edit: Perhaps its because im a windows user but im instantly finding stuff about it that I dont like![]()
Just a case of you aren't used to it. I'm a macOS user and have to use Windows 10 almost daily and it infuriates me.![]()
Learn gestures and have a look at @Feek’s software thread. Something like Rectangle suits Windows users a lot for window management.No doubt - Not sure if I will need to keep it at all after this is done but we shall seeSo far all I have done is set it up and play around for 10 mins. Might give it another play later today.
As mentioned it just takes some getting used to. Once you are acquainted with the gestures and keyboard shortcuts it is a much better system than Windows.Edit: Perhaps its because im a windows user but im instantly finding stuff about it that I dont like![]()
The feeling of worry goes away after a while, but I used Xtreme Skins on my MBA, in just a plain blue. I didnt bother with the inside stickers as they are fiddly and a pain. Its been on mine well over a year now and hasnt peeled off or anything like that.Evening all,
Rather late to the party, but I'm about to start an MBA and bought a 13" Macbook Air. I'm terrified of scratching it. Can anyone recommend any skins like Dbrand from the UK? I can see lots but I'm really not sure what's good and what's not? I'm looking for something simple; not a weird marble pattern or something.
Thanks in advance
dirtychinchilla
