Don
- 20 Oct 2002
- Oxfordshire / Bucks
Did a quick test on sprayer nozzle, it's good, don't have to re pump, all automatic , nice
Any further test feedback would be great. What products do you intend to use with it?Did a quick test on sprayer nozzle, it's good, don't have to re pump, all automatic , nice
Word of warning for anyone who uses diluted products: give any diluted solution that has been stored for a few months a whiff before using it, the GT interior cleaner 10:1 I had smelled musky but only realised after starting to clean the first door card. Will probably only make small batches of 200ml or so next time, even though the stuff has been kept in a pitch black cupboard
Used the battery sprayer on the car, 300ml of product and warm water 1.5L
Using it on the car was much much better, it manage to cover the whole Car and all 4 wheels , still plenty of battery left to do another 1 or 2 cars, only used 1 light out of 3
Cleaned very well, didn't bother getting buckets out this time
Need a video of you spraying it in a bathI suppose its not that wide, but it didn't take long to spray the car , wait 5 minutes then rinse off, it took longer to rinse off than cleaning it lol
I need to take wheels off and clean/reapply Gtechniq C5.
It's lasted almost 1 year though! And as you said, wheel cleaning is super easy.
