Raptor Lake Leaks + Intel 4 developments
28 Sep 2018
Intel Core i9-13900K CPU on Geekbench with 5.5 GHz turbo clock​
Source: https://videocardz.com/newz/intel-c...appears-on-geekbench-with-5-5-ghz-turbo-clock
7% increased ST and 37% MT on a buggy system with 'timer' issues. Quite some extra performance from a 'refresh' - compare this to 4770 Haswell and 4790k Devil's Canyon lol!
You don't have to look that far back at all. CFL and CFL-R are an easy comparison. Added some cores (real ones!), frequency bumps, some cache and an improved IMC. I know. I had both.
At least they didn't take away a CPU instruction set back then. Now that's a real lol
15 Oct 2019
Uk
Should be enough to keep Intel ahead of zen 4 though with their gains of up to 35% MT and 15%+ SC also remember that RPL can be dropped into to an older discounted 600 series board and use existing DDR4 ram which will make it a cheap upgrade option for anyone on an older platform already using DDR4.
19 Jan 2022
Devilarium
Yes, Wow. If they added 8 extra cores (50% more) and got 50% then I'd be impressed, don't forget you are taking extra cache plus core count into that 37%. Tell me why 37% for all that is good? Oh wait don't bother it's like talking to a brick wall. :rolleyes:
Why are you not looking at the number of threads instead? It seems to me like you were trying to find something to complain, which is a thing people do when a product they dislike turns out to be pretty decent. 33% thread increase for 37% mt increase is pretty decent. If you expect e cores without ht to perform similarly to p cores with ht well then... Dont know what to tell you
Also, were you complaining about amd the same way? Say the 5950x has double the cores and threads of the 5800x but it doesnt peform anywhere near that.
Alas, the number of cores and threads and the nm and the cache and all that is honestly irrelevant. Who cares. What matters is the performance and the price, whether it can achieve that performance with 10 cores on 5nm or 25 cores at 500nm is honestly a non sequitur. I don't care and nobody should.
16 Jun 2004
With 16 e-cores, that's more than enough to run Windows for everyday tasks.
They should have in built BIOS profiles that have the P cores turned off as default and only turn on, from within Windows, when needed for the most demanding stuff like rendering & gaming.
18 Oct 2002
West Midlands
It's stated as a 7% up lift in single core, yet only 37% in multi with 50% more cores. Do the maths. How can you say that even sounds remotely correct?
I was replying to some data that was posted, do you think it sounds correct/good? I don't care what name is on the packaging, you need to let go of this you just literally try and ruin every thread.
19 Jan 2022
Devilarium
Saying its a 50% core count increase is missing the point. You do realize p cores are much faster and have hyperthreading right?? So essentially it's a doubling of ecores (33% more threads) for a 37% increase. The only way to be disappointed is if you expected the ecores to outperform the p cores. Did you?
For me it's irrelevant. The mt peformance is up by almost 40%. I dont really care how, they could have done it with 50000 ecores for all i care. Performance and price is what matters, everything else is irrelevant
15 Oct 2019
Uk
A 37% increase in MT for the same or similar price is decent especially considering a 12600k is already around 40% faster in MT than a 5600X. I wonder if AMD will try again with the £300 price tag for a 7600X or if they revert back to something closer to £200
21 Oct 2002
Sunderland
what frees up l3 cache? turning off ecores? can't work out who your replying to
Yeah for best gaming performance you turn off e cores and the L3 can be utilised better by the P cores and can result in slightly higher ring clocks.
RPL has more e cores so more benefit to be gained when turned off.
OP
30 Jun 2019
modern CPUs already have good multithreaded performance. Most people want more single core speed and efficiency. That ~7% increase in singlethreaded will probably require even more power usage than the 12th gen.
It's not great, because it requires consumers to buy ever more powerful air or water coolers.
Intel has chosen to increase E-core count because they have hit a wall on what's possible with 10nm performance cores.
It's another reason why IPC gains matter, usually they involve a performance increase without needing to increase power consumption much/at all.
19 Jan 2022
Devilarium
Hit a wall? They are already up to 25% faster than their competition in single threaded performance... They werent lacking in that front, were they?
14 Nov 2005
I expect they will keep the same price as AM4 wil be for budget and teh AMD platform will be cheaper alrogether compared to the Intel higher end products
OP
30 Jun 2019
AMD looks set to catch with Intel, when Zen 4 is released. I think Intel's 13th gen could end up with higher singlethreaded performance, but only when clocked over 5.0ghz, so these parts won't be cheap or easy to cool.
It depends really. I think the 13th gen and Zen4 at the same clock speeds will give similar performance, so AMD's ability to compete at the enthusiast level end may depend on overclocking >5ghz, or maybe a premium super clocked edition at some point. It looks like 5.5ghz is going to roughly be the limit for both companies, excluding liquid nitrogen cooling :D
Intel won't be easily beaten by Zen4, but they will likely fall behind on gaming performance, with the release of Zen 4 CPUs + v-cache. It's quite easy to predict that, because the 5800X3D was already getting higher minimum framerates in some titles, than the much more power hungry, hotter running 12900KS. Power consumption comparison here:
