The Radeon RX 6900/6950 XT Owners Thread.
Caporegime
12 Jul 2007
United Kingdom
What settings do you use in MPT and in the driver?
For the 6950 XT Toxic, I use these settings for when I need max performance.
Min GPU 2658Mhz
Max GPU 2758Mhz (my sample is not very good)
FCLK to 2200Mhz (YMMV on stability)
Power limit to 425W
Fan Stop to 50c, Fan Start to 55c
Feature Control > uncheck DS_GFXCLK
That's it.
23 Apr 2021
Raleigh, NC
Min GPU 2658Mhz
Power limit to 425W
That's it.
What about for max efficiency?
19 Jan 2012
Not posted on here for a a while, still very happy with my 6900XT Reference, but decided I need some longevity from it as I don't think I will be getting next gen GPU's any time soon.
So I've ordered this.
Alphacool Eiswolf 2 with backplate.
Should arrive by the 20th.
Caporegime
12 Jul 2007
United Kingdom
Out of curiosity what is MPT ? A tweaking program ?
EDIT
Nevermind found it, Time to play around :D
Yep, I've posted a brief guide in here how to use it if you search my posts in this thread.
Let us know how it goes, curious to know the Hotspot temp and deltas etc.
