- 24 Jun 2021
- Oxon
I was thinking the sonoran desert was the hottest I've been in, but at least that was cold at night, this is just miserable.
Says you, sitting in your near freezing 28c in Lanark. Get out.Southerners are so soft, put less lemonade in your lager FFS.
Humidity.How come UK heat is more miserable than other hot nations? I always get told by people when they go on holiday to a hot country its not unpleasant like UK heat, Id it all down to our high humidity?
RIPI’m currently lying in bed with Covid 19, temp was as high as 39.2 at one point (my body temp).
It's that and that our buildings just aren't built for it. So there's no real respite.
It’s not though it’s 34 Celsius here in Blackburn and 26% humidity.How come UK heat is more miserable than other hot nations? I always get told by people when they go on holiday to a hot country its not unpleasant like UK heat, Id it all down to our high humidity?
Because I’m not sat on a beach sipping an ice cold sangriaHow come UK heat is more miserable than other hot nations?
Yeah but the soul crushing of living in Blackburn makes the weather so much worse.It’s not though it’s 34 Celsius here in Blackburn and 26% humidity.
Rhodes slightly higher 35 Celsius and 43% humidity
Getting enough water every day is important for your health. Drinking water can prevent dehydration, a condition that can cause unclear thinking, result in mood change, cause your body to overheat, and lead to constipation and kidney stonesI mean, honestly, why?
We have massive windows with no external shading/shutters which is the killer for us. Massive windows means solar gain for the rest of the year when we need it (as we're a reasonable cool/cold country). And also our insulation standards and therefore insulation installations have been sub-par for quite some time. Most homes have far too little and so the heat goes right through.UK buildings have insulation and insulation works both ways.
It's just we don't have air con at home. I am pretty sure a UK home is more comfortable than a tiny flat in **** Kok with no air con. Also why people escapes to shopping malls too.
