- 1 May 2013
- M28
If you check now on Parcelforce it should say in UKNo change since the 14th, parce force says GI logistics.
Nope, same as last week.If you check now on Parcelforce it should say in UK
Mine updated @17:19 and an email for delivery tomorrow @17:37.Nope, same as last week.
Finally got round to mine, ETA tomorrow.Mine updated @17:19 and an email for delivery tomorrow @17:37.
This is the smart thinking in my opinion. My stepson's 256Gb arrived a few days ago and honestly the smart money seems to be a 64Gb, glossy screen and the ability to put a protector on. Or, given that replacement screens are now available, not bother with the protector at all.Part of my reasoning for not getting the 512G are:-
1 - I have a habit of putting on a screen protector on my gadgets, my Switch, my phone, my cameras
2 - cheaper to get a 1TB SD than an extra 256G
I also find glossy screen look better than matt screens.
I think an anti glare screen protector is probably the way to go.
i got the 512gb as at the time, no one knew that the micro sd card speeds where almost identical to the ssd!!This is the smart thinking in my opinion. My stepson's 256Gb arrived a few days ago and honestly the smart money seems to be a 64Gb, glossy screen and the ability to put a protector on. Or, given that replacement screens are now available, not bother with the protector at all.
Think you've pretty much hit the nail on the head here. Was trying DiRT 5 last night. Ultra low quality, native res, 40fps and ran smooth as silk, reduced the power to something that would give me a bit more juice. As much as I care about graphics quality on my gaming PC (2080ti, 3440x1440) I....just don't care for the Deck. As long as I can run it at 40 or 60, I'm game!I feel like people were a little afraid of the sd card option when they were first launched so a lot of people avoided the 64gb model. Which valve were probably quite happy about. But thinking about it most of the bigger flashier games that work great on the steam deck were designed to run off the ps4 and xbox one hdds, which are pretty slow and terrible, so not all that surprising that a good sd card can keep up
The 256gb is a great choice, glad i didYep, wish I'd gone for the 256GB one now, but then here we are a year later, now coming to that conclusion, and I even mulled over it for a day. Ah well.
The 256gb is a great choice, glad i did.
Finally decked out my deck, anti glare screen protector, skin, protective cover when i need to take it on holiday with me, USB C hub and a stand though i am now abit disappointed with the stand as i thought initially the USB C plug had data pass through as well but it seems it doesn't! Got a mate to 3D print me a stand which incorporates the Anker 341 hub into it so should work a lot better than what i have now.
I think it does, everything i've read about it says it does though i haven't actually tried it yet as initially i wanted to get a switch so i can switch between my PC and Deck but then realised my HUB is HDMI where as my PC is using DP lol.Does your hub do 1 cable to monitor and charge at the same time?
I found out my dongle I use for my MBP doesn't do that.
MagGlass anti glare, reviews of it is good and seen it on Reddit as well which i had a read over before buying it.@Jay85 Which screen protector did you go for? i might get a glass one.
