The new map is great, probably my favourite over Vikendi now. I just wish the game would stop continually crashing for me.
Is it completely crashing or freezing?
Slow reply, sorry. It crashes in a number of ways: generally freezes for a couple of seconds then a crash to desktop with a PUBG crash report window. Sometimes it just CTD with no crash report, and rarely it will lock up my PC which then reboots. It has been like it since the Season 18 patch update. Previous patches season 17 & 16 was fine, but the patch before that also caused lots of crashes. I've uninstalled and reinstalled but that didn't help. Admittedly I'm running a very old PC: Devils Canyon Core i5 4690K, 8Gb RAM & Nvidia GTX 1080 and.... Windows 7Is it completely crashing or freezing?
. Still get 90+ FPS at 1080 which is more than playable (when it doesn't crash!).Slow reply, sorry. It crashes in a number of ways: generally freezes for a couple of seconds then a crash to desktop with a PUBG crash report window. Sometimes it just CTD with no crash report, and rarely it will lock up my PC which then reboots. It has been like it since the Season 18 patch update. Previous patches season 17 & 16 was fine, but the patch before that also caused lots of crashes. I've uninstalled and reinstalled but that didn't help. Admittedly I'm running a very old PC: Devils Canyon Core i5 4690K, 8Gb RAM & Nvidia GTX 1080 and.... Windows 7. Still get 90+ FPS at 1080 which is more than playable (when it doesn't crash!).
I am planning on a new PC soon, just need the funds.
My antivirus used to cause this, was a while ago now and cant remember which one I was using, worth a try.Slow reply, sorry. It crashes in a number of ways: generally freezes for a couple of seconds then a crash to desktop with a PUBG crash report window. Sometimes it just CTD with no crash report, and rarely it will lock up my PC which then reboots. It has been like it since the Season 18 patch update. Previous patches season 17 & 16 was fine, but the patch before that also caused lots of crashes. I've uninstalled and reinstalled but that didn't help. Admittedly I'm running a very old PC: Devils Canyon Core i5 4690K, 8Gb RAM & Nvidia GTX 1080 and.... Windows 7. Still get 90+ FPS at 1080 which is more than playable (when it doesn't crash!).
Have already tried verifying the local files which made no difference.
I do run MSI Afterburner. RAM usage is consistently around 4Gb, and GPU and CPU temps are fine.
Have disabled anti-virus (avast) temporarily and a couple of games played with no crashes. Will continue to try this method, thanks!
Started playing this a bit, had an 8 week break. Felt proper crusty first few games back. I'm not playing it anywhere near as much as I was now either.
Also just playing ranked, truer to the game I'm used to, all the gimics they put in standard mode broke it for me.
Frustratingly the skill level is a bit...higher generally...and I'm not not there now, but still better games imo then you get on standard.
I've not even played the new map, probably should.
Is your GPU driver up to date?Ugh.
My PUBG is causing my PC to restart every time I am about launch into a game.
I can get into the lobby fine, and run match making, as soon as its found a match my PC restarts. Literally started doing it this morning, and doing it 100% of the time. Was working fine yesterday. Have not changed any settings, tried to re-validate steam files and all ok. Other games work fine....
