BT Infinity & FTTx Discussion
Mobster
9 Apr 2012
I had a few curious questions.
The 900Mb package, is the maximum achievable speed 1000Mbps? As far as I understand it 1 Gb ethernet port can't actually achieve 1Gb, it's 940Mb, is this right? Is the Ethernet port out of the ONT 1Gb or is it 10Gb?
What is the maximum achievable upload speed?
Thanks.
Caporegime
28 Oct 2003
Chestershire
Nearly died tonight. ONT box had the red LOS light on. Seems Sky had an outage for about 45 minutes. I thought my fibre line had broke. I really need to get a damn smartphone. Hurry up iPhone 14!
Man of Honour
20 Sep 2006
Cuckoo basically resell TalkTalk so you get to use the TalkTalk network without having to deal with TalkTalk
Dragging up a slightly old post here. Do they exclusively use TT, or do they also use BTW too? I ask as I know they do PPPoE and TT (as far as I'm aware) is DHCP based. Or is it a case of Cuckoo being able to authenticate their own users?
RSR
RSR
17 Aug 2006
@RSR are you a home user? If so, how did you get TTB?
Yes, I am a home user. However, I ordered TTB under a sole trader. :p
It's £19.95 +vat for a backup line with a static IP, which I have paid upfront for the year.
Current DSL Stats, its currently on a 6dB target but should drop to 3dB later in the week.
Code:
DSLAM type / SW version:    BDCM:0xc190 (193.144) / v0xc190
Modem/router firmware:      AnnexA version - A2pvfbH045o.d27j
DSL mode:                   VDSL2 Profile 17a
Status:                     Showtime
Uptime:                     1 day 2 hours 13 min 51 sec
Resyncs:                    1 (since 24 Jul 2022 19:28:35)
                Downstream    Upstream
Line attenuation (dB):      15.9        0.0
Signal attenuation (dB):    Not monitored
Connection speed (kbps):    59523        20000
SNR margin (dB):            5.8        9.6
Power (dBm):                12.9        6.9
Interleave depth:           8        1
INP:                        49.00        0
G.INP:                      Enabled        Not enabled
Vectoring status:           5 (VECT_UNCONFIGURED)
RSCorr/RS (%):              0.0005        0.0000
RSUnCorr/RS (%):            0.0000        0.0000
ES/hour:                    0        4.50
Code:
Tracing route to bbc.co.uk [151.101.0.81]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  10.10.1.2
  2     8 ms     8 ms     7 ms  81.1.113.33
  3     4 ms     4 ms     4 ms  ae50-ner002.thw.as13285.net [78.144.1.3]
  4     9 ms     4 ms     6 ms  ae50-scr102.thw.as13285.net [78.144.1.2]
  5     4 ms     4 ms     4 ms  23.235.41.94
  6     4 ms     4 ms     4 ms  151.101.0.81
Trace complete.
Code:
C:\Users\Administrator.HOME>ping bbc.co.uk
Pinging bbc.co.uk [151.101.0.81] with 32 bytes of data:
Reply from 151.101.0.81: bytes=32 time=4ms TTL=59
Ping statistics for 151.101.0.81:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 4ms, Maximum = 4ms, Average = 4ms
Caporegime
18 Oct 2002
TalkTalk Business and Wholesale use PPPoE. They might use BTW as well but when I asked them they said it was TalkTalk.
5 Nov 2011
Derbyshire
Install went in today completely pain free. New overhead fibre to existing anchor point on house, cable drop following route laid out. Engineer used the drawcord I'd put in and came internally into the back of my wallbox I'd made a hole for.
Initially I was only getting 50/115 then the ONT upgrade/restarted (engineer said it would) and then after a ppp reconnect and the order completed I was up to full speed. Steam hit 960Mb downloading a game so I'm happy.
Ping time has halved to 8.8.8.8 as well.
V F
V F
13 Aug 2003
UK
Interesting. I'm seeing no blips on mine with the Thinkbroadband Monitor. Though Sky had a major outage last week after midnight or 1am ish.
