Genuinely wonder if there will be a rise in people tapping into neighbours electrics and the like when the alternative is giving up food for energy.
More time trying doesn’t equate to more power used. They use way less power to try a load compared to a conventional unit.No saving at all if it takes 3 times longer to dry the washing.
Play by the joulesNothing is off the cards
I see watt you did therePlay by the joules
I suspect a lot of people that complain about heat pump tumbles are using them in a cold environment so they cannot adequately do enough heat transfer fast enough
A heat pump tumble is cooling the surrounding air by transferring the heat into the drier, small rooms, cold rooms, well surrounded etc must all limit the ability for the drier to do that quickly.
The water is condensed and put in a tank/drain like a normal condenser dryer.where do heat pump dryers dump the moist air to?
Well, I was today years old when I learnt this. My 18 month old heat pump drier takes ages to dry clothes. Now I know why.Yeh, that’s the downside, you really have to have them inside the house, they will not work well in an outbuilding in winter.
(It's in the garage)![]()
You haven't heard my fridge!A fridge isn’t cooling the room it’s in, it’s heating it.
It’s taking the heat from inside the fridge and dumping it into the room, plus the energy it consumed to do that is nearly all expelled into the room as heat with a tiny bit of noise![]()
Yeah I can see many going this route.Debt Collection agencies will see an uptick in profit as they buy the debt owed to energy suppliers for the ones that went to administration, then offer the customer a 50% discount if they pay off early.
Shell done it with us and we we're paying by DD recommended by them, it wasn't until they tried to be sneaky by increasing our bill from £150 to £394! i told them nicely where to go.
So we paid £250 by standing order and then got a letter that Shell passed the debt of £1058 to Zinc.
Seen letters like this before "all threatening" but only if you don't pay it for months if not years, but we will pay it off as it our debt probably around £50 a month until they offer a discount then pay off in a lump sum.
Edit: if you open the door, the heat the pump moved out, flows back in and the process starts over again.
