Technically you're right. They did order (pay) a week before, but they reserved a year ago. Trust us, nobody's getting their decks without waiting a year!Sorry, this sounds like they placed the order a week ago, that's all.
I’ve got the 256 gb model, if they have replacement screens I probably won’t bother either then, I didn’t know they had those already are they easy to replace?512Gb? I'm not going to bother because a) etched and b) replaceable. And honestly while I've always managed to find protectors that technically "work" I've never found one that didn't affect touch response in some way.
Yep! Valve's been working with iFixit to supply replacements for most components, including batteries, which is awesome. There's an iFixit guide (and a Youtube video by UFD tech).I’ve got the 256 gb model, if they have replacement screens I probably won’t bother either then, I didn’t know they had those already are they easy to replace?
Ah cool, I’ll have a look, probably leave it as it is then. It will live in its case anyway so shouldn’t have too much reason to scratch, not as if it lives in your pocket like the phone. Did the same with the switch lite and that is still immaculate (and that screen is a lot easier to scratch).Yep! Valve's been working with iFixit to supply replacements for most components, including batteries, which is awesome. There's an iFixit guide (and a Youtube video by UFD tech).
Not going to say "easy" but if you can spin a screwriver you can do it. I bought myself a hot-air solder station and have replaced screens on several phones, couple of MS Surface Pros etc, and the deck is almost certainly easier as it's designed to be serviceable. A hot air station will definitely make the job easier as you can quickly and accurately heat the screen edges (and it'll raise your soldering capability to the next level).
Had my eye on the Anker PowerCore III 19,200mAh that does 45w over usb c it seems, £80 though.Anyone tested a decent battery bank that can charge it whilst playing? My old Anker one I bought for the switch isn’t up to the task!
Should do the job though.
I bought a generic 65W one with a mad name (Veektomx) to charge my Surface Pro and it works fine with the deck. Advertised as 20,000mAh, which is probably ambitious, but it keeps my deck topped up for hours and it hasn't burst into flames (yet).I’ll keep my eye on it hopefully it goes on sale, should be okay as isn’t the standard charger 40W? Is that on Amazon?
Edit: just had a look there’s a 60W one on there for £80 that will do the trick!
As it has a fairly substantial footprint I haven't lost it yet.How are you guys finding the Steam Deck? Which versions did you go for and why? What are you use cases?
Only had it for about 3 days but I love it so far. Went for the 512GB version as the games I like to play tend to take up a lot of space. Already filled up 650GB of a 1TB SD card.How are you guys finding the Steam Deck? Which versions did you go for and why? What are you use cases?
