- 5 Nov 2005
Just moved place from a 100MB Virgin line, got 110-115Mb wired connection. The new address doesn't have fibre and all the normal providers were quoting 4-6Mb MAX SPEED!!! I would have really struggled with that.
So I got the Three 5G hub, the map showed my new place was just on the edge of 4/5g so wasn't certain I would get good speeds.
Plugged it in, full 5G signal on the LEDs - Speedtest 545Mb LOL I was blown away. I did it 4 times and the lowest I got was about 450Mb.
I have a question though, the two antenna sockets on the router, are they for improved WiFi or improved 5G?? I suspect Wifi but thought I would check..
Also if there are any tweaks in the firmware/special settings I can change for even better performance, my ears are open!
Sounding good! I think the antenna ports are for 5G as in for external antenna......
Have you tried much yet, as in streaming 4k/HDR Netflix and/or gaming yet?
