AMD to unveil Zen 4 CPUs at CES 2022
Status
Not open for further replies.
15 Oct 2019
Uk
I always keep boxes as it increases resale value, also when selling on it shows if you have the box in pristine condition the chances are you also looked after the hardware that's inside it.
14 Feb 2008
I do the same mate, for the same reason.
Also having the packaging also helps if you have to post the item.
27 Aug 2008
London
Thats what caught my eye reading the above article .
Is it due to less wastage per wafer? Thus cheaper to manufacture.
If you are referencing zen 2, its worth remembering that the 4 core ccx was part of an 8 core CCD (die), rather than a smaller chiplet die itself.
The leak is not much to go on, but at a guess it possibly indicates they're adding another domain of independently controllable clocks, a cluster of 4 cores as a subset of the 8 per CCD and reusing CCX name.
25 Sep 2009
Billericay, UK
Not sure but I have noticed the newer cheaper end CPU's from AMD have all been using Zen2 designs. Zen 2 CCD allows AMD to produce 4 core CPU's by cutting off half of the CCX which is something you can't do with Zen3. So it might have something to do with that and they want the flexibility Zen2 gave them.
18 Oct 2012
Oxfordshire
If the recent price leaks via Canadian site is correct reflection on the price think I’ll have to not go for a 7700x at £475 and instead go for the 7600x at £329
The Canadian list price is coming at £279 and £407 though? Where you getting £475 and £329 from?
Also note the Canadian prices are also generally inflated over US prices like UK prices are so a 1:1 Canadian version is likely pretty close.
17 Jul 2019
I got it from here …
Scroll down abit.
18 Oct 2012
Oxfordshire
Scroll down abit.
Ah I had take the CAD price as with their VAT which would put ours at a similar price level then, not with a further 20% added.
But yeah if that without their sales tax and ours align then then that would be silly monies. I don't know why I keep looking, I'm not buying into a new gen till Xmas 2023 at earliest.
22 Oct 2008
Lisburn, Northern Ireland
  • AMD Ryzen 9 7950X (100-100000514/WOF) – $1158 / $1140 CAD ($892 US)
  • AMD Ryzen 9 7900X (100-100000589/WOF) – $798 / $777 CAD ($608 US)
  • AMD Ryzen 7 7700X (100-100000591/WOF) – $631 / $613 CAD ($480 US)
  • AMD Ryzen 5 7600X (100-100000593/WOF) – $435/ $423 CAD ($33
from that article
30 Jun 2019
Those prices look like the maximum ppl could pay (inc VAT). Price of £300-£350 inc VAT for the 7700X, assuming sufficient supply, seems more likely. AMD needs to price the 6/8 core models competitively to challenge Intel I think.
I imagine the 12/16 core part prices could stay high for a while, as they did with Zen 3.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Canada has 12% taxation on computer hardware. We should deduct that from those prices before adding our own VAT.
Ryzen 5 7600X:
$423.99 CAD X 0.12 = $50.88 - 424 = $373.12 CAD
$374 CAD = £240 + 20% = £288
Ryzen 7 7700X
$631 CAD X 0.12 = $75.72 -$631 = $555 CAD
$555 CAD = £ 356 + 20% = £427
Ryzen 9 7900X
$798 CAD X 0.12 = $95 - $798 = $703 CAD
$703 CAD = £451 + 20% = £541
Ryzen 9 7950X
$1158 CAD X 0.12 = $139 - $1158 = $1,020 CAD
$1,020 CAD = £655 + 20% = £786
30 Jun 2019
Those are probably the pre-launch scalp prices. If there aren't any in stock, they can try to charge more for early /pre-orders.
Or, just placeholder pricing...
Status
