Deleted User 298457
Deleted User 298457
Hi folks,
Job one of the 1930s semi is on the horizon. It is job one for a couple of reasons:
1. It will instigate some of the major tasks - wiring, plumbing
-- Wiring, I need to figure out the best way to route a "semi re-wire" for each room as the sockets are few and far between.
-- Plumbing, as above - best route, plus I need to relocate the water tank, several rads, hide some pipework and replace the floor mounted potterton boiler.
2. The upstairs toilet is leaking
3. The downstairs toilet seems to use about 12 gallons of water to flush
4. It enables the next major which is creating a rear bedroom out of the existing bathroom.
Now part of the reason in the switch is the house is on a semi busy road so noise is a key concern, and secondly the 2nd bedroom is just too big for my 2y/o. The current bathroom will be much cosier, warmer and away from the busy road/overlooking the garden.
Floor plan for context:
The inspiration:
The rough IKEA sketch to my dimensions:
I suppose my questions are around -
1. How to get started:
--- the room is currently plastered and then has lining paper, so I assume the plaster may be shot. Should I go back to brick and line every wall?
--- the ceiling is lathe and plaster and is sagging in one of the rooms. It looks visually "OK" but again may not stand up to bathroom wear and tear?
--- the floor needs lifting and then I'll assess services; the IKEA mock-up has the toilet sitting on the outside wall. Is there any tips on knocking into the existing drain? It'll be about 3 metres from the original waste pipe
2. Technically how to do a curbless shower (is it worth it?)?
3. Any glitches on what I have proposed?
4. Any tips on running a new plumbing system?
--- can the water tank be relocated to the loft?
--- is it worth ripping out the copper system and putting in plastic?
--- how much can do I before I pay a plumber to come in and fit the new boiler/commission the new system?
5. Any tips on wiring up the bathroom? I want a demisting mirror and a shaver/toothbrush charger ideally.
Definitely missed something but keen to hear your thoughts.
The inspiration:
