Has no solar panels in that postpost 10856
This is all you need plus a panel, just make sure you chose one that has a bigger capacity than the panel.
Info is all in the listing.
MPPT Solar Grid Tie Micro Inverter 260W 300W 350W 500W 600W DC18V-50V to AC110V-230V 50HZ/60HZ Solar PV Inverter Waterproof IP55 - AliExpress 13
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Where do you get that prediction stuff I can't find it.I think everyones will look the same
Here's mine;
You don't need to commission it, so not an issue.Hate to be that person, but I don't think these have a G98 cert, so I don't think the DNO would pass it when you commission your DIY system. If you've got it signed off by them then fair enough, or just running it without telling them. Just wanted people to be aware before ordering.
Wish I knew that when I did my DIY installYou don't need to commission it, so not an issue.
I think your fine if you stay under around 4kwh.Wish I knew that when I did my DIY install![]()
Just going from when I did mine (under the 3.68kW), the DNO asked for a schematic drawing, plan of the installation, a G100 form and G98 form B.I think your fine if you stay under around 4kwh.
It's not uncommon for people to have to use up their annual leave whilst working their notice.Boris can get another holiday in yet.
You don't need permission below 3.6kWh but you still need to inform them. Above 3.6 kWh you need permission.You don't need to commission it, so not an issue.
Looks like this doesn't exist if you are on GoOn the Octopus website under account. There is a link that says "view my balance forecast" then toggle the "crystal ball mode" to show the predicted energy cost rises for Oct/Jan/Apr
I am on Go faster and not there for me either I guess when you are on fixed it's not as necessary as you know your energy use from past years and the price is stableLooks like this doesn't exist if you are on Go
you know in the past I would have said not in the UK. buy at my parents kneck of the woods there are a group going round letting down car tyres of cars they feel are "too flashy" "too expensive" or "too wasteful".These people are rioting over energy bills so what do you think they’ll do to someone flaunting electricity?
Maybe leave an extension lead in the garden so they can charge their phones and you may be ok.
Not there for me, might be that I'm on variable payments though.I am on Go faster and not there for me either I guess when you are on fixed it's not as necessary as you know your energy use from past years and the price is stable
Miner is ,£689 for two year fixI think everyones will look the same
Here's mine;
It only works on single rate tarrfis , else how would it be able to predict when you used on peak vs offpeak.Looks like this doesn't exist if you are on Go
Any solar panel you can find 24v and up, just the inverter needs to be of a higher capacity than the wattage of the panel.Has no solar panels in that post
