That's still hideous though, compared to just a year ago. Vast swathes of people just won't be able to afford it.Working out my own usage, this doesn't seem as bad as I feared? I'm working that out to £483/month without cutting back on usage and without factoring in load shifting to the Octopus Go cheap period.
I wonder how far I can get that down? £350?
Use it at work or on mobile (that is charged at work) so that is saving nothing on the consumer side this end.If we all stopped using OCUK I'm sure we'd save about 20% on our leccy bills
2318kWh in electric for 12 months approx.
2922kWh in gas for 12 months approx.
Agreed.
Absolute most gas I have ever used in a month was 1,400kwh.
So at the new October rate that's about £200. Then about £110 worth of electric so this winter my worst bill should be no more than about £310.
Take off the £67 or what ever it is as well and it's really not that bad.
Applying those rates to my last monthly bill would change it from £150.48 to £250.69. Based on 423kWh elec and 8kWh gas in 30 days. Christ.
It's going to be really difficult in large parts of Europe where the temps really can plummet over the winter.
that's enough to warm 17 million UK homes, two-thirds of the nation’s total, for a winter’s day, so if we extract 50% from own waters, just need 5 ships a weekshould arrive on August 22. Attalos, an LNG carrier with a capacity of 174,000 cubic meters, is currently carrying this Australian LNG. It recovered the cargo in Malaysian waters, after a transfer from the LNG carrier Patris.
its the auxilione data the +84% = 3634/1971 oct/apr capsHow have you calculated the unit prices. I assume there are meant to be based on the same % increase over current cap rates but the math doesn't work?
For instance
October increase 84% = 52.14p
January increase 23% = 64.13p
Condensing boiler what are the optimum settings?
Water?
Heating?
Interesting my seems to be set to 70c on one setting at 56c on anotherWhat temperature should a Boiler be set at | Baxi FAQs
Boilers come in all shapes and sizes. If you want to know what temperature should a boiler be set at, take a look at our guide to get a good idea.www.baxi.co.uk
Ta, working hard to minimise exposure to rates since been on variable since all started. Plenty of duvets, blankets, jumpers this end and house only 7yr old.Those are both incredibly low usage figures.
If you aren't in a frozen cave come winter time that is very good!
So that means ours could be going up by 100% as Octopus are only charging us 26.4p on a variable rate at the moment.Pretty much confirmed the October price cap
I was spot on with the prediction
Ok based in Jan 2021 usage I am over £700 a month, yikes l
700kw x .54 = £378 + sc
2500kw x .14 = £350 + sc
90.97p for electric apr 23!!!
