Permabanned
- 23 Apr 2014
- Hertfordshire
Evidence required.....we already have evidence the Tories are not upto the task.She is so useless.
Labour are just not up to the task
Any time she opens her mouthEvidence required.....we already have evidence the Tories are not upto the task.![]()
ExactlyHeh! Are any of them honestly? None of them are capable of running the country. Would we even be here if we did...
Really depends on the flat.Not UK flats as they are really small with no spare space, everything done to keep the developer in huge profits. No outside space balcony due to some obscure law by some Tory minister in the 50`s
Again its Tory MP and donors on the boards of housing stock to keep the plebs down and pay for it through the nose at the same time.
Yeah the increase is lower because the French gov has spent BILLIONS in taxpayers money to artificially keep it low. Who do you think will end up paying for the BILLIONS spent?I guess this is accurate? EDF is increasing prices by 54% over in the UK as well, I guess that helps keep the French prices down . . .
Currently we only use 7-8kWh a day and we aren't on holiday.My average daily electricity usage is around 20kWh. While we were on holiday the idle consumption of the house was 7kWh per day. I think I need to go around and see what's using so much.
However, one would assume UK EDF customers will still be be subsiding French customers (and the taxpayer), to an extent.Yeah the increase is lower because the French gov has spent BILLIONS in taxpayers money to artificially keep it low. Who do you think will end up paying for the BILLIONS spent?
When on holiday. These things need to be on:Currently we only use 7-8kWh a day and we aren't on holiday.
You must be leaving lots of stuff on.
They also make about 70% of their electricity from Nuclear.I guess this is accurate? EDF is increasing prices by 54% over in the UK as well, I guess that helps keep the French prices down . . .
Who's paying for the ridiculously high energy prices here?Yeah the increase is lower because the French gov has spent BILLIONS in taxpayers money to artificially keep it low. Who do you think will end up paying for the BILLIONS spent?
The French are ****'sI guess this is accurate? EDF is increasing prices by 54% over in the UK as well, I guess that helps keep the French prices down . . .
Yes we are doing the same with cooker microwave etc,When on holiday. These things need to be on:
. Fridges and Freezers
. Security alarms
. Sky/VM box if got things on record.
Everything else can be switched off. I’m even turning off the oven, microwave and alarm clock to see if that makes a difference
The same people that pay private companies billions lolYeah the increase is lower because the French gov has spent BILLIONS in taxpayers money to artificially keep it low. Who do you think will end up paying for the BILLIONS spent?
Probably the sky/vm box, sure I read somewhere they're pretty heavy on the energy usage. The fridges and freezers, unless really poor energy rating should be fairly low for most of the day, same with the alarm really.When on holiday. These things need to be on:
. Security alarms
Don't know if they've been improved but my sky box didn't really change when in standby, seemed to be a consistent ~40w.Set top boxes aren't that much, maybe 40 - 60w during operation. 5 - 10w in standby? The TV will be more than a top box.
