- 8 Jan 2011
- London, UK
Nice. What is that OS skin you're running? Looks awesome.Quick and dirty run at "stock" for my 12700k on a Asus Z690 TUF D4 board with TVB enabled (5.2 single core).
Single - 2,028
Multi - 22,980
Temps are mainly a result of running the D14 with a single fan running @ 750RPM max. I should probably fit the second fan but tbh the temps are perfectly fine in gaming even with a higher ambient temp.
A quick run at 5Ghz all core scored ~ 24k so not too bad.
Really need to get into tweaking this system properly but its just too damn hot atm.
