RE2 **** it at launch in the exact same places the 3070 did in @Tired9 vid(when you ran from the back to front of the precinct building), different build eh, but haven't played it since, but I don't need to argue about it if it isn't doing it now and the 10Gb's sufficient as I'll take it as a win that it doesn't run out anymore.
Maybe MS/Nv can fix MSFS so that it doesn't run out of vram anymore as well, but they might not be able to and 10Gb is insufficient in this case too.
That right there is all that needs saying, you buy what you can afford, live with the best gpu at that pp-if it's not one of the top gpu's in the range then obviously it can't do everything as better options are there for a reason.
At the end of the day no matter how good anyone thinks a 3080 is, it's not bullet proof due to the vram which runs out on a few occasions, still a great gpu.
I prefer straight shooters saying, I can't afford it or the card choice gives me a better option.
I did show this with several sources earlier on but apparently they were using a "different build" so don't count....
