Yeah it’s a lot of extra real estate!Going from 27" to this must feel like a night and day![]()
Not sure how best to arrange my browser windows. Used to run two side by side but that’s crazy big now!
I’m going to experiment with Powertoys Fancyzones to manage this.Yeah it’s a lot of extra real estate!
I can’t find it on the OC website? What is the warranty on the monitor?
Casing | Panel | Parts and Accessories (optional) |
3 Years | 3 Years | 1 Year (cables and bundled gifts are excluded from the warranty) |
Appreciated mate. Glad the reviews and info have helped, and that helps support the siteOrdered (well pre-ordered) thru @Baddass link![]()
I ordered "NEOMOUNTS BY NEWSTAR VESA CONVERSION STRIPS - VESA 100 TO 200X100, 200X200, 400X200, 400X400 - BLACK (#Neomounts by Newstar-FPMA-VESA425)" for my Ergotron HXReceived mine today and coming from a 48CX i just expected the VESA mounting to be the same, its not. My adapter plate only does 300x200 max. Anyone know of a good quality 300x300 VESA adaptor that’ll work well with the Ergotron HX arm?
No problem with that. Which input are you using and is the cable certified for it?Anyone else having issues getting hdr AND 4K activated in windows 11? It just refuses to do it. Gonna upgrade the firmware and try again.
Have you tried scrolling down the resolution list? The first section of resolutions listed is normally only configurable for 60hz, the second section for pc allows 120. Basically there are 2 lists in that scroll down window.Yeah the cable says it’s 4K 120 certified but I can’t seem to get more than 4K 60 sdr. Must be the cable if you guys are all ok. It’s in hdmi 1 next to the display port which I think is 2.1. Also my text is blurry in windows… can’t seem to fix it.
