You forgot Modern Warfare 2 and Warzone 2.![]()
Those two don't count if you are over 45
If Avatar is any good, I will eat my Lisa Su portrait.
No DLSS 3 thoughIn the 3 games without DLSS3 the 4090 was ~1.6x faster than a 3090Ti. The 3090Ti is 1.17x faster than the 6900XT at 4K according to the TPU charts.
That puts the 4090 in raw raster as around 1.87x the 6900XT. If top N31 is 2x faster than it is ahead in raw raster by a margin. If it is 2.5x faster like some rumours state then it will be ahead by 2 performance tiers.
When it comes to RT RDNA2 loses 60-70% performance where as Ampere is closer to 40-50%. If RDNA3 is the same as RDNA2 then with a 2.5x boost in raster it will probably be competitive with the 4090. With an improvement to the relative raster performance to even 50% it is likely to be ahead.
Now rumours may be incorrect and RDNA3 may under perform but 2.5x the shaders with 50% more memory bus width and faster ram combined with the much higher clock speeds vs RDNA2 makes me think 2x performance is going to be the low end outside of CPU limited scenarios.
Really the numbers are there so unless there is a massive IPC and perf/shader regression (I expect some but not like 50%) then it does add up.
I don't think AMD have much to worry about and I really think that N33 is going to be nipping the heels (around 90% performance) of the 4070 (sorry 4080 12GB) which is using AD104.
Yes. FSR 1, (RSR) available in every game. FSR2/2.1available in some games.Don't AMD have their own dlss thing?
They do now with fsr 2 and 2.1 is on par with dlss 2 iq in both stills and in motion.Don't AMD have their own dlss thing?
Indeed. All frames will be the real deal rather than fake ones to boost numbers but do nothing for input latency.No DLSS 3 though![]()
Is 2.1 on par or thereabouts? Not played anything utilising 2, let alone 2.1.They do now with fsr 2 and 2.1 is on par with dlss 2 iq in both stills and in motion.
So do you believe that AMD will restart production of RDNA 2 to fill the void?
6900 XT has come down a lot...
Hasn't been the case for months.it's well established that game heavily favours AMD GPUs
Look at the Valhalla benchmark thread on this forum.Yep, there is no way the 3090ti beats the 6900xt or 6950xt in AC Valhalla, it's well established that game heavily favours AMD GPUs - Im surprised Nvidia included it in their benchmarks since they knew it would make them look bad.
From what I can tell only the 16gb rtx4080 is matching the 6950xt's performance in that game, which is not good for Nvidia but that's still like 20 or 30% faster thanbthe 3090ti
