It's actually £1999! - exclamation mark included![]()
Just waiting for them to add an "only" before it
haha the ! added the extra £500 obviouslyIt's actually £1999! - exclamation mark included![]()
These are only placeholders at present, they could easily increaseI see some of the 4090 cards have a price added in the description now - £1999...wowzers
Yep. Anything can happen with the mysterious exchange rate on the day of release. It will probably push the cards up a few more hundred quidThese are only placeholders at present, they could easily increase![]()
Lucky for you it doesn't do anything of the sort. It generates single frames inbetween two properly rendered frames - smoothing motion but not affecting any interaction. If you were shooting based on 50 frames a second before you're still shooting based on 50 frames a second now, only you also get a visual effect of almost 100 frames per second.
With all this new DLSS 3 power, I'd have thought they'd have been pushing 8k gaming a lot more, a la 3090 marketing. Guess they know themselves that it's too much of a stretch? Or has there been mention of it?
The coke bucket from the mining boom ran dry and now that nVidia execs are on a comedown they realise nobody cares about 8K gaming and have instead gone for a more realistic push for high FPS 4K gaming.
Good for those ****s! Gotta cater for that 0.0000000000000000001% crowd eh.Tell that to digital foundry, they will be doing 8k benchmarks on the 4090
The internet sadly forms echo chambers, even ones we all think we are free of, DF will be the death of themselves eventually unless they come back to reality in the now.Tell that to digital foundry, they will be doing 8k benchmarks on the 4090
Let's hope! The forum will be a riotWhich of course they will do.
I was watching some AIB product release videos and the 4090s come with silent mode by default which is 450w and you have to switch to gaming mode for better performance. Pretty incredible how power hungry these cards are
If you're talking about frame 1 the first time a game loads, sure - that will be held, but no reason that's any different from the usual 3 or so frame buffer that cards do unless you enable reflex/low latency/low-zero prerendered frames.Not quite, in order to insert this fabricated frame in-between two real frames; the graphics card has to delay showing you the oldest frame thus there is an inherent delay.
The 4090 is the only decent card of the generation so far so if you have to buy one its really the only one that makes sense.Yeah, none of you should get a 4090 day one. Bad idea.
*hovers mouse pointer over 4090 pre-order button*
