Have they took the good guess prices off the cards now on main site?
I know there are only placeholder prices right now but the difference between standard versions and the OC version can run up to a £170 difference! If you get the standard version All you need to do is set the GPU clock higher before you use whatever program you want to use and you save a fair bit of cash unless there’s something I’m missing about the OC versions?
Thanks for the update and that makes sense and appreciate that we don’t have much information at this time.More to it than that, some of the OC versions use 600W PCB, so can pull more power, superior cooling solutions and as such they *MIGHT* be able to run at higher boost frequencies, but as there is no reviews or real world testing I cannot deny or confirm this.
But lets say for instance a 450W reference card runs and boost in a 2600-2800MHz region max and an OC 600W version runs 2800-3000MHz, then what your paying for is the extra speed the OC card can maintain whilst gaming, but whether any truth or not, no one knows yet.
Sounds like someone * MIGHT * of had a play with these new cards to make sure they work as intended for their customersMore to it than that, some of the OC versions use 600W PCB, so can pull more power, superior cooling solutions and as such they *MIGHT* be able to run at higher boost frequencies, but as there is no reviews or real world testing I cannot deny or confirm this.
the card should come with a meal voucher for 1 and a bottle of lube to make up for how rough its going to **** me over the pricingSounds like someone * MIGHT * of had a play with these new cards to make sure they work as intended for their customers
Shame these new cards are sky high as i would have liked a Strix to replace my 3090 but with prices floating around the £2100+ , I'm just not prepared to pay £400 - £500 over an FE for an AIB![]()
you're right there, apparently there is to be an investigation concerning tory donors shorting the £.1.06 now it's amazing if you are invested in USA stocks.
I'm up 4.93% since Friday on the FX rate alone
all the tory donors are probably making a killing
Think i will go for the 4090FE don't fancy getting stitched up like a nana blanket on the AIB cards pricing![]()
Considering its looking to cost £480 over an FE ( if the placeholders are to be believed ) that best be some 5 star Michelin meal Voucher and a bottle of Dom Perignon for lube!the card should come with a meal voucher for 1 and a bottle of lube to make up for how rough its going to **** me over the pricing
@Gibbo, so if all is good in terms of currency rates, are the flagship 4090s gonna be around £1800? so the lower tier 4090s could be £1500 to £1600
Any indication, or estimates, so we know what to prep with in terms of cash.
I very much doubt the FE will be 600w , that is AIB territory but you should be able to up the power limit a bit over stock .. i reckon 500w max maybe 520w at a push as the 3090 FE had a 350W TDP but could be upped to 400W with afterburner etc .... if you are able to shunt mod the new cards then will be a ot more.I would check up to see if the FE does the full 600W
Yeah man that needs rounding up for sureZotac GeForce RTX 4090 Trinity AMP Extreme AIRO is now just short of £2,060![]()
It not MSI, actually it is EVGA terminated their partnership with Nvidia but it not because EVGA not making enough money on their GPUs. Accorded to insiders and former employees, EVGA's GPU business are profitable, CEO Andrew Han made too many bad business decisions, micromanagement, disrespectful and abusive treatment toward EVGA employees. They dont like Andrew.dont forget, the main reason why MSI pulled out of their partnership with Nvidia is because they were not making enough money on their GPU's, Nvidia price cap so company's have to price out cards on a certain level,
so they probably wont increase the prices to absurd levels, maybe the rrp for a 4090 will be 1500-1600 tops, like the 3090 rrp on release....
I can imagine everyone buying their 4090s direct....
