call me dumb but i cant seem to find any info in where to buy the new 7000 series in the UK . I'm assuming we a a later release date than that of the 27th September (today).
look around 2pm today thats when it will go live to buy
Honestly with most blocks etc needing a new bracket anyways it seems like making it thicker was wasted. They should have just got companies to make a new mounting system for the lower Z height and be done with it since the holes otherwise are same and it honestly wouldn't of been any different, made chips about 10degree cooler and saved 5-10watt still.
Thanks. Can the speed deficit be corrected through a cpu or bios upgrade? or are we still looking at new motherboards.
You can set whatever fan curve you want. The CPU will target 95C and adjust clock speeds and voltages to stay within that under heavy multi core workloads. If you run lower fan speeds and thus have less capacity for cooling all that will mean is the CPU will boost a little lower as it can't get rid of the head as quickly as it might like.So will there be any way to run say a 7600X under a NH-D15s and still keep your fans at about 600rpm with these chips or is the fan curve right out the f*ning window?
Serious question: if the things constantly Turbo until they hit 95 deg, how are we going to keep our fans and pumps silent-ish whilst still adapting to load?
I'm sure there's a solution, but not one which jumps out at me.
Thnks so much. Not built a PC since i built my 5960x about 6-7 years ago.look around 2pm today thats when it will go live to buy
This is whats attracting me the most with no performance hit in games . be good for long sessions in my sim rig (when its built)eco mode. reduces temps signifigantly and only a minor performance hit, sometimes its the same vs stock in games
I think the 13600k could be the one and you dont care for upgrading for years after by cpu drop in upgradeJust watched the gamers nexus 7600x review,
Looks like i will be getting intel 13th Gen instead.
Keeping the fans low doesn't adapt to load though.You can run something like fancontrol and keep the fans low.
having fans blasting full speed won't help you any. The heat transfer from the die to the top of the IHS is the main issue.
Interesting. I figured I'd start undervolting rather than overclocking one day with Moore's law dying and companies chasing the last drop of performance via crazy power levels.eco mode. reduces temps signifigantly and only a minor performance hit, sometimes its the same vs stock in games
Appreciate what you're saying about the heat not being dissipated to the IHS, that's new info to me. GN suggested it was due to an uneven surface on the IHS itself. Either way I'm sure keeping fans/pump running in line with load would be at least somewhat beneficial. I can set my fans to run off water temps, so I suppose my real issue is the water pump.
Reading Anandtech's article it seems to suggest you can set predetermined or manual TDP etc. limits that will hit before the 95 deg limit, so basically will boost like a Zen 3?
Yeah Zen 3 was not exactly like the Conroe daysoverclocking days are pretty much done for real usage and everyday use undervolting has been the way for quite awhile now to increase peformance ,improve power and temps![]()
Still; I managed to eke another 100 odd MHz max and 200 MHz all-core out of my 5900X: now it looks like I'll be reducing peak and sustained speeds to keep my rig silent.yeah same here with 5900x improved stock scores and games clocks mainly 4900-5000Yeah Zen 3 was not exactly like the Conroe daysStill; I managed to eke another 100 odd MHz max and 200 MHz all-core out of my 5900X: now it looks like I'll be reducing peak and sustained speeds to keep my rig silent.
