Unless you are a gamer. CPU performance has become largely irrelevant, graphics card pricing has gone to the stars.What a time to be alive!
Just thought I provide some depressing balance to your current euphoria.
This time next years we won't be millionares, we will be gaming off of the chipsets of our motherboards.And Nvidia's new cards generate frames without the CPU
CPUs becoming more irrelevant to gaming
Yeah sorry I still don't think that's a good thing. How do you for instance play a competitive shooter if its filling in frames and making them up just to get the FPS counter to go higher? Is the game registering that inserted frame? Does that mean if you shoot someone in that frame it hits them or is it because it's inserted to smooth things out then it doesn't work.And Nvidia's new cards generate frames without the CPU
Agree. As a gamer, I'm just looking for the 13400f to be cheap(ish) and decently performant. Hopefully that'll then put pressure on AMD for a 7600 non-X sooner rather than later. I can see (fingers crossed) some pretty sweet combo's from both AMD and Intel in the next six months or so for gamers. Whether the same can be said for GPUs, well..The area that Intel can definitely fight in is below the top tier AMD parts.
There's only so many reasons to overpay for mid range performance.
I don't think they can claim any performance crown without asterisks such as *running at 400W all limits removed.
Is there any easy way to do a comparison between motherboards? What are the key differences between those 3? I need to get up to date on motherboards as I haven't built a new PC in over 12 years.https://www.overclockers.co.uk/asus...-lga-1700-ddr5-atx-motherboard-mb-6jg-as.html not as bad a price as expected, still expensive though
£100 more than the Z690 with not much in real world extra for most users.https://www.overclockers.co.uk/asus...-lga-1700-ddr5-atx-motherboard-mb-6jg-as.html not as bad a price as expected, still expensive though
Lets all accept something - that it's fantastic that both AMD and Intel are releasing exciting new CPU's that have us all talking. Gone are the days of 5% IPC, same core count. Now we have exciting V-cache, E cores, CCX's, etc etc and each generation seems much more substantial. What a time to be alive!
Good for the apex to be back, but that means it will probably cost around 1k? It was already way more expensive than the unify X / tachyon, so yeah...is it really worth it?![]()
@Nickolp1974
Auto subs but yeah, Apex back to apex things. To note, TG starting to have A die at 6600 bins so will have to pay close attention to product id’s to determine IC.
The cpu ocing was better hands down on the asus, at least at in terms of accessibility, and especially the AI oc got you like 90% of the way there, but still, 300€ extra for a little bit better bios. Ouch
Any difference in memory ocing between z690 2 dimmers and z790 2 dimmers?You can get the Msi i790 edge and do what apex does.
It's gimmicky at best and while your fps counter will show 120fps the game will still feel like it's running 60fps.Yeah sorry I still don't think that's a good thing. How do you for instance play a competitive shooter if its filling in frames and making them up just to get the FPS counter to go higher? Is the game registering that inserted frame? Does that mean if you shoot someone in that frame it hits them or is it because it's inserted to smooth things out then it doesn't work.
It certainly doesn't make the CPU irrelevant either as it still needs to do loads of data passing for AI in game and such. Daft comment. Maybe hyperbole?
