They have good cpus on expensive platforms plus so many people waiting for 3d cache models.Zen 4 aint shifting.
It's official, 7700X is the most interesting CPU in the lineup
What's the most interesting Ryzen 7000 CPU?
With Ryzen 7000 reviews out, we're wondering, which of the four models would you buy?www.techpowerup.com
My take is that AMD needs a single CCD design for future CPUs, so that performance scales better over 8 cores.
That and b650 boardsThey have good cpus on expensive platforms plus so many people waiting for 3d cache models.
Cheers for putting these modules up:If there is a kit you’d like to see post a link to the TeamGroup website of the kit you want.
TeamGroup Vulcan 32GB (2X16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit - Black (FLBD532G5600HC36BDC01)
Order TeamGroup Vulcan 32GB (2X16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit - Black (FLBD532G5600HC36BDC01) now online and benefit from fast delivery.www.overclockers.co.uk
Any chance of a price cut?
According to MLID, Microcentre has experienced a large boost to sales of the Zen4 since it started giving free away DDR5 RAM with every CPU
Same guy reported very low microcentre zen4 sales couple days back, before DDR5 bundle campaignThe guy sponsored by microcentre reports a large boost in zen 4 sales.
So can you still technically load XMP profiles on AM5 if you get one of the kits without an EXPO profile?
This. Also an EXPO kit might have two or more profiles. For my kit EXPO profile 1 sets the primary timings, however profile 2 sets some of the secondary timings too. I’ve not really spent much time tuning memory yet, still dialling in curve optimiser as you can definitely improve clock speed and performance with negative offsets.None EXPO kits work but require manually setting up and some reports even then they are not running at set speeds correctly, EXPO kits work out the box without issue on AM5. Our EXPO range has increased a lot now, 6000MHz C30 kits due this week.![]()
I appreciate your candourSo were making 15% based on current landed cost and the pound can go either way. So not that much room I am afraid for discounts, not until TeamGroup and other memory manufacturers start dropping DDR5 pricing but right now its a bit of a bum fight trying to get stock. Once supply improves prices will drop for sure!
You sure can load XMP Profiles on non EXPO DDR5 kits on AM5 Motherboard. Asrock X670E Steel LegendSo can you still technically load XMP profiles on AM5 if you get one of the kits without an EXPO profile?
Yes - the ASRock X670E PG Lightning allows my RAM's XMP profile to be selected in the BIOS.So can you still technically load XMP profiles on AM5 if you get one of the kits without an EXPO profile?
Yes they can run higher,I just have not even started on the Ram timings or speed yet.Looks like ASRock have got the XMP profiles sorted.
Wonder if the same is true for other board manufacturers?
@gerardfraser - have you tried bumping up the RAM frequency to 6400, at slightly higher RAM voltages?
EDIT - just noticed those are Samsung modules - can Samsung modules handle higher frequencies?
