@Gibbo Are you likely to have either of the Palit cards in stock on the 12th?
Nope. They had a fan issue.
Yes, but in Tomshardware article they said that by default BIOS does not allow more than 450W - so they did not say it cant be changed via slider, it just meant that default powerlimit is 450WIndeed.
Is it not the BIOS that determines how much power is available on the slider?
I am seeing FE adapters with 4 connectors, so Tom's could simply be wrong about the 450w limit on the BIOS.
pre-scalped for your convenienceOCUK were worried about scalpers buying up all the stock so they came up with a cunning plan to scalp the cards themselves to put off any other scalpers!![]()
The fact the FE comes with a 4 x 8 pin adaptor would lead you to believe it has a 600w limit as that is overkill for 450w alone ... i do think it will be able to be adjusted but not to 600w ( + 33.4% ) more like 504w ( +12% ) although the FE 3090Ti is hard locked to 450w afaik and can't be adjusted where as the 3090 FE can be adjusted for 350W to 400W in afterburner so will have to wait and see what we can actually do with the FE when reviews are out next week hopefully .Yes, but in Tomshardware article they said that by default BIOS does not allow more than 450W - so they did not say it cant be changed via slider, it just meant that default powerlimit is 450W
Techpowerup on the other hand said you can change Powerlimit on FE to 600W.
So we will need to confirm on 11th, but I am fairly certain you can adjust power limit to 136% in Afterburner.
2080ti had +26% / 3080 had +16% so hard to say for sure - lets see on 11th.The fact the FE comes with a 4 x 8 pin adaptor would lead you to believe it has a 600w limit as that is overkill for 450w alone ... i do think it will be able to be adjusted but not to 600w ( + 33.4% ) more like 504w ( +12% ) although the FE 3090Ti is hard locked to 450w afaik and can't be adjusted where as the 3090 FE can be adjusted for 350W to 400W in afterburner so will have to wait and see what we can actually do with the FE when reviews are out next week hopefully .
They show up under your recent view items at the bottom.How are you seeing the prices?
Agreed, I fancy a 4090 but can't help but feel it will be complete overkill for my needs.I’d rather pick up a 3090 for £700 than pay £2000 for a 4090.
90% of pc gamers are playing Fortnite, Call of Duty, GTA5 etc and a 3090 will handle those games effortlessly for years.
