- 9 Jan 2010
Aye so little stock ..Hopes of getting one today waning.
Well this the thing, my pc kicks out so much heat I've never used the heating in the last 3 years. Good insulation and a fast pc is all you needWell, my work doesn't demand fast GPU, only entertainment does. Much harder to justify, aside "Shiny new toy, me want!".But yes, shiny new toy, me want! I shouldn't, definitely bad corpo sucking us dry but winter is coming, will save on heating?
Very true and the 4090 has annoyed a lot that only got 3090ti recently too at £2k+ and now the £2k+ game is being played out again while their 3090ti is now half the price...![]()
Its not little for such an expensive card. Even 3080 had less stock than that, If I remember correctly OCUK had less than 100 3090 in stock on launch dayAye so little stock ..
Yes, with 120Hz you should always be able to have that FPS with current games and even in new coming games for a while. CPU shouldn't limit you with that refresh rate.Nvidia website !
Using it on LG C1 65" 120 so should be better for me for 4k gaming , if it doesn't then ill just spend 1k next month when the new CPU are out.
Nic Cage says soonerGame over... All 4090s will be gone in 60 seconds then.
Its not little for such expensive card. Even 3080 had less stock than that, If I remember correctly OCUK had less than 100 3090 in stock on launch day
people viewing and having the money to buy are two different things lol , some people just go on to view out of curiosity to weigh up going for a 4090 or 3000 seriesOn another well known shop not sure if this is right but it's saying 8392 people are currently viewing the Asus 4090 Strix.
Viewing doesn't mean buyingGame over... All 4090s will be gone in 60 seconds then.
Lots of people like to view products through the glass of shops but only tiny fraction actually buys them.Hopes of getting one today waning.
Nah man, brasses and coke is the wayLook on the bright side. If you don't get a 4090 today, you can always buy a PS5 + Series X and a 65" OLED instead and have change.
That was the great thing about a 2 PC setup, would put the heating on for a hour to warm things up, then I'm in my vest and shorts as it was so hotWell this the thing, my pc kicks out so much heat I've never used the heating in the last 3 years. Good insulation and a fast pc is all you need![]()
All you have to do really is check fleabay for pre-scalping ads and there isn't any. Remember before when the 3080 launched and ads for a 1k-1.2k gpu were popping up all over the market places.
