Nope. I didn't have all the info I needed until yesterday. Narrowed it down to 3 and just waiting until one of those three is available, or AMD relases something strong enough.Twinz did you get yours.?
They are very quiet and they are overkill - the YouTuber bangforbuckgamer has been doing some 4k gaming videos on his MSI suprim 4090 and he set the fans to max speed to see what happens and the card runs at 48c... it's just ridiculous but yes of course at max speed they are loud it's just to show how overkill the cooler is, by default pretty much all 4090 cards don't run their fans higher than 40% speed and it makes them super quiet
Finally, I’ve found a positive in buying a Strix OC . Don’t feel as bad now.Yeap, it's ridiculous how quiet my Strix 4090 is. Fans spin at 1100RPM maximum on my sample - whereas founders edition cards spin at 1500+, which is much louder.
If you're not bothered by noise then FE is the way to go, but AIB if you want really quiet cards!
Yes, my side glass is squashing it in!Anyone know of a right hand 12 pin adaptor?
You could buy the FE card and watercool it for the price difference though and have a cooler running gpu that doesn't resemble a breeze block
Yes, but it's in test phase and seems random. Not many people got it yet, apparently (I haven't D: ).
Is there any evidence you need to be currently using GFE to get the email invite?
Also, most likely you have to have a proper country set in your NVIDIA account. I just noticed mine had no country set at all... Corrected!Well the terms and conditions say that they are inviting Nvidia gamers and the only way they know that is through GFE I suppose. Sure I read somewhere that you needed to have GFE installed.
I can get a brand new 3090 non Ti for under $1k right now. Another "outlier"?
Is that under language settings?Also, most likely you have to have a proper country set in your NVIDIA account. I just noticed mine had no country set at all... Corrected!
No not at all. I'm not in the market for a 4090 but I definately wouldn't be paying for an AIB card unless I desparately needed a gpu or had no self controllooking at reviews and AIB's the FE has really closed the gap personally wouldnt pay the extra for the AIB's
Preferences (where you set email etc. too), but just noticed the language thing too and switched from US to GB just in case.Is that under language settings?
FE cards have wobbly fans though in most of the reviews, sure going to get more wobbly as the uneven force wears on the bearinglooking at reviews and AIB's the FE has really closed the gap personally wouldnt pay the extra for the AIB's
Well, if only things were so easy. Fact is, Apple has a huge fanbase which doesn't really even look at other brands at all, hence for them Apple IS a monopoly and can dictate any prices they want - big number of fans will still buy it (as they jacked up prices in the past a bunch of times by a lot, already). There's a limit to price raises of course and a good balance to find. Possibly Apple found it with current prices, but I am not convinced we won't see higher in the future. NVIDIA on the other hand doesn't seem to care one bit about competition indeed but they do have a large loyal following as well - their true fans do not care for AMD and won't even look at these cards. This is why NVIDIA can raise prices and see how it goes. So far, it goes well with 4k series for them.
Isn't that just the nature of fluid dynamic bearing though?FE cards have wobbly fans though in most of the reviews, sure going to get more wobbly as the uneven force wears on the bearing
