Horse for courses. As a 3090 strix owner I thought the 4090 strix was the ugliest card out of all the AIBs (Gamerock excluded)
Glad we agree on the gamerock
That's weird are you logged into GFE with the same account?I got the e-mail but no notification or anything under redeem.
The GPU size of the AD104 is under 300MM2 so is closer to the GA106 rather than the GA104. It also has a 192 bit memory bus like an RTX3060.Loooool. Probably wise though. Come back with a rename/better price (I realise I'm daydreaming on the latter)
Unlaunching The 12GB 4080
16GB GeForce RTX 4080 on track to delight gamers everywhere November 16th.www.nvidia.com
Never made sense as the different tiers of Nvidia products are well known and to have two 80 versions was not not very smart.The GPU size of the AD104 is under 300MM2 so is closer to the GA106 rather than the GA104. It also has a 192 bit memory bus like an RTX3060.
So even calling it an RTX4070 is generous to Nvidia. It is more like an RTX4060 or RTX4060TI.
Not a bad way of approaching sales however. Hopefully they're targeting particular customers rather than just randomised based on account email addresses they hold. I used to do the survey things for them until I ended up doing no gaming between the survey requestsI’ve just had the email from NVIDIA to buy a 4090 FE. Like thanks it’s such a privilege you’re letting me buy your horrendously overpriced GPU.
Not even interested in buying the crazy priced 4090, I’m happy with my 3080![]()
guys
30 series in pc
in what order is the change done?
remove drivers
remove card
insert 4090
install new drivers
or
remove card
insert 4090
install 4090 driver on top
or
remove card
insert 4090
remove 30 series driver
fresh instal 4090 driver?
Hope NV can start knocking them out in decent enough numbers so those who want one can get their hands on one soon.
guys
30 series in pc
remove drivers
remove card
insert 4090
install new drivers
or
remove card
insert 4090
or
remove card
insert 4090
yeah i always doing that when installing new cardI just shut down my comp, removed the old card , installed the new card and then installed the nvidia drivers over the old ones with "clean install" ticked
The current drivers you have won't support the 4090 anyway unless you updated to the latest ones already
