I haven’t seen anyone cross their legs since the carpet in primary school. That brings back memories![]()
My back hurts if I try to do that
You can see the logo has a gradient of light brighter on the right at 7min in this video. So, yes, it's normal.For those with the new Suprim is the new RGB logo on the heatplate meant to be brighter at the right, dimmer on the left by default? 90% sure it is and it's meant to fade across, but just wanted to be sure.
Personally i wouldn't buy psu cables from aliexpress with no awg rating for the cable given. Amazon has those cables with awg ratings (you want 16). You want a single pcie port on your psu to connect to just 1 4090 gpu adapter, so you need 4 x pcie cables (or 3 if the 4090 uses a 3 way adapter, like mine). Cablemod sells cables too (but expensive afaik).Is it possible to use https://www.aliexpress.com/item/32907954506.html 2 x PSU-PCIE that has a double end to connect to 4090 ? Or does that not work.
I haven't got an invite and I've got two 30-series FE cards.I do wonder how many 4090 FE are in stock, they do seem to be sending a fair amount of invites to buy.
Well £1699 for the FE (plus £8 for saturday delivery) wierdly enough sounds like the bargain of the year!
I know the answer to that, my i7 7700K paired an msi 4090 is besthas anyone found a review that compared CPU's using the 4090 to see which CPUs are best?
Nice man, enjoy - hoping I get an invite tooIt’s on it’s way!
Nice. I currently own a 6800XT but would like the chance to buy a 4090FE I've installed GeForce experience free version. Can I or how rather can I get a chance to buy an FE.It’s on it’s way!
So you just registered and got an email. I'll try thanks.
My knees don’t do that anymore either.My back hurts if I try to do that
That’s the best unboxing I’ve seen.
If gross margins are staying the same (and indeed falling in 2022) it means that at the aggregate Nvidia aren't pushing prices higher relative to the cost of making the chips. If you plot a chart of shader flops per £ generation on generation over the last decade you're actually seeing the cost of compute go down considerably. GPUs have become a lot more powerful and cost a lot more to manufacture.You're having a laugh right ?
i did the same 3pm-4pm delivery slotIt’s on it’s way!
Nice Saturday afternoon treat - love it ; enjoyi did the same 3pm-4pm delivery slot![]()
