- 12 Feb 2006
- Surrey
What do you mean with swings?The swings that people go through with the Pixel phones is crazy.
Just in that the highs and lows with owning a Pixel can swing rapidly. LolWhat do you mean with swings?
Should show charging rapidly.How do you know how fast the phone is charging? I'm testing my new Samsung 25w charger and it still only says "charging" on the lock screen, not "fast charging" or similar, as i was expecting.
That's great to hear as my 6 pro was constantly dropping it's connection. Pegging it back to 4g was both better for battery and signal strength. What are the perks of 5g again?Should show charging rapidly.
Signal is definitely a notch or 2 stronger over the 6 Pro. Hold 5G better where the 6 drops to 4G.
Nothing really if you already have a good 4G connection.That's great to hear as my 6 pro was constantly dropping it's connection. Pegging it back to 4g was both better for battery and signal strength. What are the perks of 5g again?
Yes I am able to see "charging rapidly" when using a different cable.. I guess I cant just reuse cables from the past, they need to support the kind of wattage required.Should show charging rapidly.
Any good quality cable will do as its under 3 Amps and nearly all are this rating. When you need over 3A next step is a 5A cable.Yes I am able to see "charging rapidly" when using a different cable.. I guess I cant just reuse cables from the past, they need to support the kind of wattage required.
Thanks.
That's weird, i've already linked my Starling card/account to my google wallet on my P7 pro?Argh, Starling have just informed me I can't link it to my Google wallet on the P7 Pro. It doesn't work on this device yet![]()
Hmm, every time I try it doesn't work. I've sent them another message.That's weird, i've already linked my Starling card/account to my google wallet on my P7 pro?
To be fair it's what you agreed to when you ordered. The bonus of ordering direct was that you didn't have to wait for your watch/budsTried to claim the Pixel Buds Pro’s from Curry’s but the store isn’t yet ready for claims, and should be open on 1 Nov. A bit frustrating as I’m making do with some **** headphones at the moment and massively missing my AirPods Pros
