- 21 Jul 2005
- Officially least sunny location -Ronskistats
I could only see two in the UK.
Is that miners offloading ampere cards?
same card as me, although my gf wants to build a new PC so I'm giving her mine as an excuse to get a 4090 only FE though, not paying a penny over the already insane price of 1700Good luck, hope you get one.
I'm just glad I'm sitting this one out, my 3080 Ti will do me for a couple more years or so.
Yes the EU energy regs are dumb. Eg they limited vacum cleaner power, so you just had to spend longer vacuming, hence total energy used is the same.
Just wastes your time.
Hmmm I counted 11 RTX 4090 FE in UK. 55 RTX 4090s in UK total and 1 in Malaysia.I counted eight on the first page.
Guys any idea why my suprim 4090 is only getting 16k in port royal!? 3900x 32gb ddr4 850w PSU.
The 3090 wouldn't get the frames I'm getting with this. I've got a 175 Hz panel wanted to get the most out of it.The 3090 would do that too lol
From Sept 2017 it's actually a 900w limit, may explain why he's had to go all hand held/battery now.They did ban using motors over 1600w and Dyson kicked off and went all anti EU. Though his most powerful hoover only uses a 1400w motor so he clearly isn't that bothered and Dyson push battery powered hoovers now which are even lower wattage around 500w. So maybe the EU limit drove innovation?
Can you post up your results link , might show something going on ? have you checked cpu usage during the benchmark ?Guys any idea why my suprim 4090 is only getting 16k in port royal!? 3900x 32gb ddr4 850w PSU.
https://www.3dmark.com/3dm/81369974? cpu usage spiking bet50-100Can you post up your results link , might show something going on ? have you checked cpu usage during the benchmark ?
that is very high cpu usage for Port royal , have you tried it with hags on and off ?https://www.3dmark.com/3dm/81369974? cpu usage spiking bet50-100
stock/half cores disabled yields almost same results my gpu is being held back by like 30% idk whythat is very high cpu usage for Port royal , have you tried it with hags on and off ?
bench r15 currently at 3066 dont think its a cpu issue?stock/half cores disabled yields almost same results my gpu is being held back by like 30% idk why
Sounds like something is hogging the CPU performance as GPU should not be dropping off at all during the test as it is a GPU bound test , i have just rerun it myself to check usage and overall usage never exceeds 27% and the most one core gets to is in the 40% range . Also checking the hall of fame for your setup can see you should be around the 27000 range . You have tried with Hardware Accelerated GPU Scheduling on and off ?stock/half cores disabled yields almost same results my gpu is being held back by like 30% idk why
Are you sure you've got no frame rate limit on?Guys any idea why my suprim 4090 is only getting 16k in port royal!? 3900x 32gb ddr4 850w PSU.
