Deleted member 258511
1st of November.Thanks mate. Whats the ETA on the 990 drives? Will they have better capacity potentially?
Just purchased the i9 13900kf - From looking at Benchmarks its 10% boost in MSFS at 4k so should look amazing.From looking at benchmarks its not a massive improvement but it depends what you want to do with your pc , I'm thinking I just got 4090 so it makes complete sense to buy the newest i9 13900k , MSFS you get over 10% boost at 4k so its the go to CPU for lovers of that game now no doubt about it. I'm also a Photographer and Video editor and again from the benchmarks this is the CPU for that.... This CPU isn't going to be for a lot of last gen guys because like you said a lot of games will only give you a 3 % boost max.Its 2-3 fps!!! Yes you are losing up to 5% of the performance. So what? Worth spending another £1000-£1500 to upgrade the mobo and cpu? Who cares.
yea the same people with a vested interest in selling you the latest stuff.,.... what a coincidenceIMO it's best not to argue with this group of people. Gibbo, 8pack, and many reviews out there for 4090, mention over and over that 4090 needs to be paired with latest CPU's for it to make sense.
my thoughts exactly but u were brave enough to say ityea the same people with a vested interest in selling you the latest stuff.,.... what a coincidence
if you got 2k for a GPU then your likely easily persuaded to upgrade the rest of your system.my thoughts exactly but u were brave enough to say it![]()
Yes depends on the game though. My 5800x3d gets 40 frames less than a 12900k overclocked on 3440x 1440p ac creed Valhalla but probably good on other games. You should check out YouTube for comparisons on what you play.Will my 5900x be a bottleneck?
and then you have the EK waterblock to cool an already supercool gpu.. i would rather buy a x670 motherboard at this point and not look like a clownoads got convinced they need some cable mod cable
Can I ask what motherboard you went for to go with your new cpu?Well this turned out to be a super expensive month for me but on the plus this time next week ill have a Epic PC ready for 4k GamingJust purchased the i9 13900kf - From looking at Benchmarks its 10% boost in MSFS at 4k so should look amazing.
I have a 5950X and get a higher score on the superposition with my 3090 than I do with the 4090 overclocked past 3100 MHz using the settings defined for the benchmark here. IMO totally bottlenecked. I've ordered a 13900k 7200mhz ram and a Z790 because of it. Plus I have a 240hz 4k monitor and feel DLSS with the 5950X will hold me backWill my 5900x be a bottleneck?
That's bizarre as my 4090 comfortably beats my 3090 score on superposition using exactly the same setup bar the gpu change with a 10900K , i cant see how a 5950x is held back in that benchmarkI have a 5950X and get a higher score on the superposition with my 3090 than I do with the 4090 overclocked past 3100 MHz using the settings defined for the benchmark here. IMO totally bottlenecked. I've ordered a 13900k 7200mhz ram and a Z790 because of it. Plus I have a 240hz 4k monitor and feel DLSS with the 5950X will hold me back
Will be a lovely upgrade no doubt
no idea won't go higher Thant 110 fps. I scored 14xxx with the 3090 and 13xxx with the 4090. Made no difference at default or overclocked. I had the same problem with Port Royal too with the 5950X. Intel just works better for those. With the 5950X on Port Royal I would score the same whether I was running at 2050 or 2250 on the 3090. Hoping too with the water block the 4090 will add the usual 100 MHz on the clock like all the last Nvidia cards ive owned after water blocking them.That's bizarre as my 4090 comfortably beats my 3090 score on superposition using exactly the same setup bar the gpu change with a 10900K , i cant see how a 5950x is held back in that benchmarkWill be a lovely upgrade no doubt
https://www.3dmark.com/3dm/81422053? my 3900x and 4090 is this a bottleneck or pc issue? extremely low scores
Im actually beginning to think its a Nvidia driver issue with older AMD cpus. My time spy and ex scores are awful too. Haven't even bothered with fire strike. Speed way is ok thoughThat’s weird. I’m getting 13,777 with a 10700k.
My graphics score is 19,000+ and my CPU score is lower than yours.
The frequencies showing for my 4090 are lower than yours too!
I went for this oneCan I ask what motherboard you went for to go with your new cpu?
