- 29 Nov 2007
my mouse is hovering over the buy buutonI really liked the pico 3
Just found this if anyone is interested in trying it out.
You can get USB Tethering Enabled on the Pico 4 and use Virtual Desktop wired! This really helped shave a few ms off of latency and really helped reliability. The trick is to get your Pico 4 into USB debugging mode (tapping the software version a few times, then going to Developer in the Pico 4). Then, connect a USB 3.0 cable and run this adb command:
adb shell am start -n com.android.settings/.TetherSettings && adb shell input keyevent 20 && adb shell input keyevent 20 && adb shell input keyevent KEYCODE_ENTER && sleep 2 && adb shell input keyevent 4
That will enable USB tethering, which Windows 10 should see a new network is connected. Virtual Desktop will prioritize this connection -- you can even turn off wireless after connecting with Virtual Desktop to save on some battery. I recommend putting that adb command in a .bat file to make it super easy to apply.
Reddit - Dive into anything
www.reddit.com
Might be interested?
That's completely awesome.
Just so I understand, the command you run, that's just within CMD?
My two issues with the Pico were the inability to use VD via USB, and the lack of support for OpenXR.
That looks like a solution for one of them.
Any idea about OpenXR support?
using VD, well after the posts on here i unboxed it and tried again, i also tweaked the heck out of my wifi and whereas before i was getting 400mbps/i now got 866mbs, without a doubt it made the image better. 150mps hvec 40ms latency, its now within a grasp of being good enough but just not there judders on the turns and sometimes artifacts on the track. its probably just a very specific use case for me in iracing. no doubt over the coming weeks if more can be squeezed out of the cable approach it'll be good enough. i am prepared to waitThere is something seriously wrong if you are saying a pico 4 doesn’t have as good an image as a CV1… that’s insane. How are you using it, virtual desktop?
I found in MSFS in particular I had to dial back VD’s sharpening significantly (down to 30% from default 75%) and that massively improved the image. I’m actually now getting something that looks almost as good as the G2 but with a more usable image due to the better lenses. Might be the same in iracing?
All I can say is that with virtual desktop in ultra and steam at 100% (something like 3164x3164 per eye), no upsampling options in MSFS, 150mbps and HVEC I am now getting a stunning image in MSFS which I am actually preferring to the G2. Performance wise it’s 33-34ish fps vs 39-40ish fps.
@lokiss fair enough, I have no experience of the Neo 3 link so can’t comment on it.
Something weird going on there. The CV1 is poop in comparison to the Pico 4. Did you do like me and forget to wear your glasseshave boxed the pico4 up and it is being returned, its higher res than my CV1 but the picture is worse, i tried to like it but prefer the cv1. may try the neo3 link. did try halflife alyx etc and that was awesome, but if it looks like garbage in iracing then thats no good to me as im 99% in iracing, the compression is worse than screendoor imo.
was like comparing a dvd SD to a crappy encoded HD rip
next headset please
Something weird going on there. The CV1 is poop in comparison to the Pico 4. Did you do like me and forget to wear your glasses![]()
i did at first, that was last week, used some old contact lenses which i couldnt see properly, found some specs that were able to fit within the visor and the picture got better, got even better with upping the wifi throughput but its still just not there for me, a shameHave you tried bumping the rate down? I get really bad performance on 150. My FPS tanks and the headset lags as I turn my head.using VD, well after the posts on here i unboxed it and tried again, i also tweaked the heck out of my wifi and whereas before i was getting 400mbps/i now got 866mbs, without a doubt it made the image better. 150mps hvec 40ms latency, its now within a grasp of being good enough but just not there judders on the turns and sometimes artifacts on the track. its probably just a very specific use case for me in iracing. no doubt over the coming weeks if more can be squeezed out of the cable approach it'll be good enough. i am prepared to wait![]()
Can someone check something for me please. When looking at a dark image, can you see a giant lighter circle in the middle? Like 90% of the screen, there's a really large circle of light. It's really offputting when you notice it. The glares are pretty terrible.
Managed to get star wars squadrons working. Had to install the pico streaming assistant, but it's working now. Since that's a dark game, it's pretty bad with this headset. Too much glare, and this giant circle is annoying.
I read the Pico 3 has not had an update in 5/6 months, that does bold well for the pico4 if they not doing regular updates.
That's good. Would you be able to link whee I can read the update history as I can't find.There was a new update 2 days ago. A bunch of fixes, the 2nd firmware update since i've had it. New apps keep showing up, as well as updates to the video viewer.
So my earlier suspicions were correct, there is a very significant overhead on running the Pico, the G2 will achieve approximately 25% better performance with the same settings.
Wifi 5 is 866Mbps, Wifi 6 is 1200Mbps.Wi-Fi could still improve a bit perhaps, mine reports 1200 for comparison.
Now I've removed that, I'm able to use 150Mbps setting without the horrendous lag.Thats why i held back, even if it is an improvement, it will be very minimal and not enough to justify an upgrade just yet over the Quest 2. I did some more pcvr last night having not used it in awhile and it still blows me away playing games like Alyx at how detailed the world is.I have been following this thread and as a complete VR novice, I am curious to know what people's choice would be for starting in VR at this point. Lots of posts are saying that its not much of an improvement over a Quest 2, but if you were going to buy one headset out of the Pico 4, Quest 2 or Reverb G2, which would people go for?
