- 24 Sep 2015
Use the feedback assistant and report it.
I didn't know about feedback assistant - done.
Just reading that Ars review now. Wondering why does the M1 Mac use 28.51GB of SSD space but the Intel is half that at 14.9GB. Is there a massive amount of Intel code still in Apple Silicon macOS?
It's dropped support for quite a few slightly older Macs, all the drivers and framework for those models are no longer needed.not that I need the space but its impressive how a new OS and features can free up so much space, saving me the hassle of doing a clean install, which I usually like doing.
Considering they are still selling Intel Macs this year, I think there will be at least two more versions of macOS that support it.Is it the next MacOS that drops support for Intel? As I imagine that will be quite something in terms of responsiveness and being frugal on space.
If they don't break it out to GUI then hopefully you'll be able to set it via preference files, although i haven't seen anything yet which is a little worrying. It is an utterly stupid idea though, especially in corp environments, likewise with IP tracking being enabled by default as it seems to really fudge with internal DNS and VPN.And items that run at login no longer have the option to hide them so I'm getting multiple apps appearing on my screen when I boot.
I'm not sure how to use it in my current workflow. Do you have any tips?Stage manager is definitely growing on me.
