Hostile_18
Hostile_18
Can anyone point me in the right direction for telegram/discord FE alerts ? Trying to bag one for my son. Cheers
I'd appreciate the same
I'd appreciate the same![]()
Something doesn't sound right there , 60 in gaming is shocking when watercooled... 100% sounds like a contact issue somewhere. Have you contacted EK about this yet or anything about it on their FB group?Got my Ek waterbclock on my 4090FE last night and I am disappointed in EK.
Quality of the waterblock is shocking, no where near the levels they used to be.
The block doesnt cover the whole board and as such there are two LR22 phases right next to the power connector which are uncooled.
Not convinced that the thermal pads they send with the block make a good contact all over. I put it all together and stripped it down and there is very little pressure on the pads.
Same with the gpu chip. Nvidia has a very strong spring which clamps their block in good contact with the gpu, the ek waterblock just uses 4 small screws. There dint seem to be much pressure and there is a warning not to overtighten as you could crack the chip (thats the problem you get when not using a big spring.
And lastly, i didnt get much time to do much testing last night but bearing in mind its on its own watercooling circuit with a 560mm rad and 280 rad, the gpu still gets to 60C in gaming.
And thats not even doing any overclocking. But something weird going on power wise I think, I never go above 48% power and never draws more than 280w but it was boosting to between 2850 and just over 3000 last night.
I wish I had waited for waterblock reviews as some of the other blocks available look much better and covers the whole circuit board.
Generally speaking, even with aircooled cards, thermal pad thickness and hardness play a very very large role on GPU temps, and especially hotspot. How big is the delta between your gpu die and the hotspot at max wattage, something like 400-450w? That should give you a clear indication on whether your thermal pads allow good contact between the cooler and the die. 10C was perfect for the 3090, but it seems for the 4090 below 10 is actually kind of a normal.Just saw on reddit there is only one other person who posted with the waterblock and they are getting low 40s. Also I see somebody posted that you should use only the 1mm pads on the gpu side (EK instructions say otherwise though!!!!!!!!!!!). Perhaps the pads are keeping the block from making good contact with the gpu?
I'm going to have to drain my loop again arent i>![]()
Yeah does sound like you have a contact issue for sure, for reference my strix would only get to low 40 with 520w and a cpu in the same loop so 60 for a gpu on its own loop would point to bad contact, is it even touchingJust saw on reddit there is only one other person who posted with the waterblock and they are getting low 40s. Also I see somebody posted that you should use only the 1mm pads on the gpu side (EK instructions say otherwise though!!!!!!!!!!!). Perhaps the pads are keeping the block from making good contact with the gpu?
That's a real shame! Keep us updated with it please as I also have the EK FE block on order and have looked over the installation manual in preparation, and it does say 1mm and 1.5mm on the core side.
Thats not true at all!! Watercoolling mode altough is expensive,still is the best cooling method without worring about noise, space or high temps ....My Strix 4090 runs cooler than that.
TBH, IMO it's not worth the expense of custom watercooling the 4090s. The higher end models such as MSI Suprim, Strix and AMP extreme all have such huge air coolers that there's 0.1% performance improvement from watercooling.
The air cooled cards are also very quiet, I'd wager most custom water cooling setups are louder, when you consider pump and radiator fan noise.
Not worth the expense, unless you plan to volt/power mod your cards (with physical mods) - then of course custom water (or LN2) is required.
Same! I've got an EK FE block on preorder with OcUK and really didn't want to read this!
Hopefully it's just a bad mount @Greebo. Is this a block with an active or passive backplate?
