I can't say I notice any input lag to be honest. That's between the MiSTer and original hardware on my setup, using an 1ms monitor and I have used my OLED on gaming mode as well. However, I might not be sensitive to it.Wouldn't using an lcd defeat the purpose of using fpga since lcd would create lag resulting in software emulation type of experience?
Bit confused, but different controllers have various input lag. I use 2.4g wireless controllers and notice no lag. Original hardware or MiSTer.Isnt that to do with the controller itself? If using an arduino running daemonbrite joystick interface thats supposed to have been tested as lowest input lag?
I believe the small box cases are specifically laid out for USB Hub - DE10 - IO Board, but there are other options. You can get the MiSTer Consoliser from Huber, completely different looking board - Link. I much prefer the smaller set up personally.Just trying to understand the module upgradability of these units - can you keep adding to the stack depending on your needs or do you limit yourself and have to choose what you need most. For example, does the the I/O board need to sit directly above the mainboard or can you put it anywhere? I'd like the MT-32 module but would that mean it takes up a slot that would forfeit another part do you know?
No problem, FYI I've edited my post a bit with some more info.Thank youThat's very useful and that vid is excellent, going to save that
I want a Mister more then ever now
Retro Gaming Cables would be worth looking at, their cables are brilliant. Highly regarded amongst retro community. I own quite a few of their 'pack-a-punch' scarts and would definitely recommend.Think I have managed to source one now and want to get everything setup monitor side ready just in case
Will be outputting from the VGA on Mister and I have component BNC input on monitor - anyone know of a good place to purchase or any decent brand names to look out for etc? Also, anyone know if I need to have a sync input connected on monitor too?
Thank you,
No worries, you're in for a treat. I own the Analogue FGPA products, but have been genuinely blown away by the MiSTer. Such an amazing device.Brill , thanks again Joe , will take a look now
Amazing device.
It's the first time I've used a proper screen since the 90's and I forgot how much of a vital part it is.
I have a 20" too but that thing is a beast and don't really have the desk space. Did plan to just use this 9" just for setup but i really like it and it does look great in motion.Enjoy, MiSTer is amazing. Nice choice on the caseStill need to do a bit of tweaking but almost fully setup now and it's probably the best thing I've bought computer-wiseAmazing device.
There's likely more I could do to improve the HD output so not a fair test against the monitor, but the CRT adds so muchIt's the first time I've used a proper screen since the 90's and I forgot how much of a vital part it is.
. Possibly, they come up quite a bit through my work (they are still widely used in the medical industry). Will keep you in mind and if I see anything, i'll let you knowEnjoy, MiSTer is amazing. Nice choice on the case.
I would absolutely love a PVM. Any tips on where to pick one up?
